IntelDisplay Power Savin Technology keep turning itself on
    Aspire V5-571 running windows 8
    I have a Aspire V5-571 running windows 8
    My screen wont turn off auto brightness adjust so it keeps dimming in and out light to dark every minute
    • I went to battery settings, change plan settings and advanced options and then turned off "enable adaptive brightness when plugged in or not"
    • I tried running on different battery plans high performance and balanced
    • I have also disabled the sensor monitoring service via the services.msc
    I think I have found the issue but still a problem:
    Ive opened the Intel HD graphics and disabled the power saving feature in the Intel Control Panel under Power -> Power Source "On battery"and this seems to fix the issue for a little while however if I remove the power supply from the laptop or reboot this feature I just turned off turns itself back does not stay unticked in result i get my screen dimming in and out again.
    I found this person had the same issue but noone gave a solution:
    he describes it better than me.
    Please any assistance is highly appreciated
    I just saw in another thread here not regarding the same issue but something similar where Administrator Brink says it could be something to do with the power management software that came preinstalled I had a look and only thing popping up is ACER powermanagment and it shows me this screen:
    Should I close and eject? Will this solve the issue? I still have the problem why does Intel keep resetting the changed feature maybe its conflicting with ACEr power management?
Intel HD Graphics - Display Power Saving Technology
Ok, this is driving me a little crazy. I've posted on the Intel forums, thought I'd make a thread here as well. This concerns an Acer Aspire V Nitro laptop, which comes with an Intel HD Graphics 4600 card. My issue is with the stupid adaptive brightness feature, which supposedly automatically...
Graphic Cards
BSOD playing L4D2 & when turning into high perf power plan
Hello everybody, I own my MSI laptop since last october. I have random BSOD's, I would say 1-2 per week, and especially when I am playing left fo dead 2 (2-3 per hour), and when I turn the high performance power plan on (5-6 per hour). I have a killer network card, and I heard that this card...
BSOD Crashes and Debugging
Mobile technology rant...
Bob Saget. I read today that Nokia is gearing up for three new Lumia Windows Phones for this year. One of which is codenamed Catwalk. Basically, it is the successor to the Lumia 920, and instead of being built out of durable polycarbonate, it will be built with aluminum so it's lighter. ...
Chillout Room
Your Opinion: Technology
Your opinion: Overall, does the technology available today make us smarter & well informed or ultimately more dependent on it? I was presented this question by a friend that's in IT. I'd like to get member's input. I have mine, of which I'll post after awhile. Thanks.
Turning to the past to power Windows' future:An in-depth look at WinRT
Source A Guy
Windows 8 News
