Power Settings Not Maintained
    Hi, I have made a cutomised power configuration for my laptop, which prevents it from shutting down etc, when it's on main power.. It works OK, but keeps resetting itself to the Balanced (default) configuration after a couple of days. Any advice please?
    Maryland USA
    Are you disconnecting the main power at any time?
    It may be switching to balanced whenever the power feed to your laptop is interrupted either by loose, faulty, or intermittent connections.
    May also switch due to high temperature..
Windows 8.1 Power settings automated
hey guys, I build out tons of machines of all makes and models for demo scenarios. One of the things that is the same on all devices is our custom power settings. Is there a way to copy the power settings and apply them to any new laptop we build out? Example: Laptop 1: Power...
Performance & Maintenance
Surface Pro 3 and Power Settings Issue
I have a Surface Pro 3 and am unable to independently set the ‘Turn Off Display After’ and the ‘Put The Computer to Sleep’ settings different from each other when plugged in to power. When I change them and save them to different settings, they both revert back to the same setting the next time I...
Drivers & Hardware
Screensaver and power settings are not working in Win 8.1
Hi everyone, My screensaver and power setting to turn off the display has stopped working, and these were working the other day. The only thing I have changed is I updated iTunes. I have tried a system restore to before this and this did not fix this. Among other things I have tried a clean...
Best Power Settings - Win 8 Server
Hi all, Please could someone advise, direct me to some advice on what the best settings are if I am using Windows 8 as a server. I was it to be as eco as possible shutting off when not in use but quickly booting when necessary. I have heard of software's that do this but don't know; 1)...
Cannot Oplen Power Change Advanced Power Settings Link
Can't switch power settings
Hi, My little sister just got a new Asus X201E Laptop with Windows 8. The problem is that it is not possible to switch between a "power saving" and "performance" profiles. Every time I try to select the "power saving" mode, it jumps back to the "performance" :( The screenshot is in Czech but...
power settings
What is the difference between balanced power setting versus performance power setting? I've been doing some googling about but there are only some references to laptops for actual performance gains. There was no clear answers as to what those settings are for each.
