Hard-drive transfer speed issue
    Windows 8.1 Professional 64-bit
    Hello everyone,
    This is an issue mainly with my hard-drive and not Windows 8. I attached an image to help resolve this problem. Whenever the 'Data transfer rate' reaches 100% I get huge performance issues. This happens whenever I deal with a few running programs that are accessing and writing data.
    The speed transfer of this HD is about 3Gbits I think and is interfaced with SATA. Does this mean I have to buy a new HD with larger transfer rate or am I missing something?
    I used to run Windows 7 but switched to 8 and with the new task manager I 'managed' to notice the performance with my HD.
Hard drive issue
Hey, bought a new computer HP 110-414 desk top ! It is supposed to have 1TB hard drive but it shows in the specs as 786 mb out of 814 mb what's up with that ?? I have checked the Apps & all are in small MB's ! Wonder what will happen when the max is reached on drive "C" and where the system is...
Drivers & Hardware
Hard Drive - Read/Write Speed Cap?
I've tried googling and fixing this issue for 12+ hours. Here's the deal: whenever I open new programs, my hard drive jumps up to 100% usage. The problem is my read/write speed looks like it's capped around 10 MB/s. The manufacture says I should get an average of 156 MB/s. I have a 6 month...
Hard Drive issue
I have an Asus k series laptop, running windows 8. I recently got a hard drive failure error, it occured a few times for a week then stopped. Two days later i went to restart my my computer and now it says theres an error and wont boot, after diagnostics it says it could not repair my pc. After...
Drivers & Hardware
PCIe Hub & External USB Drive File transfer issue
Help. This is driving me nuts. Not sure what's happened and pretty sure I have not done anything to silly. Background : New Windows8 install all update and drivers : system running absolutely fine. Issue :Copying data from one drive to another via any hub on system...
slow transfer from sd cards to hard-drive
i have two cards, a class 6 and a class 10. The problem is not reproducible on my laptop, which transfers around 8mg/sec. i've had intermittent problems since upgrading. At first i was getting what i consider a normal transfer rate of 8-10 mg/sec with each card. But several weeks ago I began...
Performance & Maintenance
Strange Hard Drive Issue
Hello all, hope someone can help: Here's my drive config (all SATA): Disk 0 - Intel 128gb SSD - Windows System Disk 1 - 1TB Western Digital - Media storage Disk 2 - 250gb WD Work / project files Disk 3 - 250gb WD VMs for testing Mainboard - Asus P8P67 Pro In my system event viewer, I get...
Drivers & Hardware
Hard drive and DVD RW Drive issue on Windows 8 RTM
So the same issues i had in Windows 8 Release Preview too and i was hoped to be fixed in Windows 8 RTM but still the same! So the issue about HDD is that i'm using two hard drives; one is Western Digital which is primary with Windows 8 installed on it and the other is Hitachi which i use it for...
Drivers & Hardware
