Problem : There is no wireless interface on the system
    Hello, I am running an Asus Windows 8.1 64bit lappy and I can't connect to the internet. I clicked on the internet connection icon in the tray and the green menu slides open and usually it shows the Airplane mode and below it the Wifi connections but instead it says "No connections available". I've tried the ethernet cable, and still can't connect to internet. I opened command prompt(admin) and keyed in :
    netsh>wlan show network mode=ssid
    netsh wlan show drivers
    I've checked Device Manager and there is nothing with exclamation marks, though I was having problems with the miniports which I've sorted out following instructions i found in this forum.
    Screenshot Device Manager:
    network and sharing center i tried connecting from here by right-click -> connect/disconnect but then the green menu slides open green menu slides on right screen
    airplane mode definitley off screenshot airplane mode off
    command prompt that gave response no wireless interface:
    command prompt
there is no such wireless interface on the system
I tried to delete the network and the results I got were "there is no such wireless interface on the system" I am connected to wifi and the network is John 17. The screenshot shows my attempt in command prompt."]
Network & Sharing
Intel Management Engine Interface Problem
In Device Manager I have an ! against Intel Management Engine Interface. In Driver Properties it says: This device cannot start. (Code 10) An invalid parameter was passed to a service or function. I have also seen errors related to this in a recent Perfmon report. I have tried to...
Drivers & Hardware
Having a wireless problem
I'm having wireless problem. It just won't connect to the internet and I've tried turning the airplane mode on and off but it won't work.
Network & Sharing
Wireless Photoviewer Problem
Hell win8 forum. Ive got a problem with win8 -8.1 photo viewer on my dad new asus laptop he bought about a month-2month ago. Hea got a Epsom xp315 wireless printer, connected to wifi not usb. When he prints a photo in photo viewer he gets a error next to the print jobs and then only prints out...
Drivers & Hardware
Laptop wireless problem
Hello! I have recently bought a new laptop (Asus K56C) and installed Windows 8 and also all the necessary drivers. But when I try to connect via wireless to my router I keep getting this message instantly (as if it doesn't even try to connect): "Can't connect to this network". The weird thing...
Network & Sharing
Please help wireless network problem
Hello, I just upgraded from Win7 64x to Win 8 pro Build 9800 x64 last night and ever since I cannot connect or even see any wireless networks listed. Nor is my wireless network adapter show up anywhere including the device manager. The device manager shows two unknown devices here are the...
Drivers & Hardware
