Solved wireless & wired network problems, How to diagnose it ?
alaslipknot
Problem solved after updating to Win 10
Hello,
it started two days ago, every now and then i start getting one of these errors (or all of them) :
the most frequent one is :
ERR_CONNECTION_FAILED
When this one appears, google searches still works (from the address bar) but i can't open any websites, including google.com or youtube.com
then there is :
ERR_CONNECTION_RESET
This one happens with certain websites, like speedtest.net, actually it is happening right now while am righting this post and google and eightForums and other websites works perfectly
Also sometimes the internet in the browser is completely down, nothing works while skype & dropbox and steam are still working, and sometimes nothing works.
Like i said this happens with wireless and wired network.
I am sure that my internet and my router are fine since i tested it with 5 devices (win7 laptop, ubuntu laptop, macbook, Android smarthone and an iPhone)
Also i just want to say that my internet in this pc has become very slow, while in other devices it's constant 8mb/s.
I am trying to update the pc to win10 at the moment and it's been 2 hours and the download is only 2% ...
I tried netsh winsock rese and restarted the pc and the router and the problem still persist.
I turned off completely my anti-virus (avast free) and all other security services from Microsoft and still couldn't find a solution for this.
I have a doubt that this is related to my other problem,"can't save settings like default app, folder and icon size", and i was going that upgrading to win10 will solve all this but i clearly can't do it with a broken network.
Can anyone help me to solve this please ?
Thank you and have a good day
    windows 8.1
Did you reboot the Internet equipment?
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Lets see what ipconfig can tell us. Do this twice. First when all is working and again when the problem occurs. Post output from both please.
To collect IP configuration information easily, do the following:
Open a Elevated Command Prompt:
Press WIN + X to open Start context menu.​
Select Command Prompt (Admin)​.​
Paste the following into the Command Prompt window, exactly as shown, including double quotes:
cmd /c "ipconfig /all > postme.txt & ping yahoo.com >> postme.txt & reg query "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings" | find /i "proxy" >> postme.txt & notepad postme.txt & del postme.txt"
and press ENTER.
A file will open in Notepad. Please copy and paste the contents here. Close the Notepad window and the file will be deleted and the Command Prompt window will also close. Post results in a reply here.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
and press ENTER.
Hi, thanks for the information am sure this will be useful someday, i'll paste the result below but i just want to say that my problem has been solved after updating to win10
Windows IP Configuration
   Host Name . . . . . . . . . . . . : AlaSlipknot
   Primary Dns Suffix  . . . . . . . :
Wireless LAN adapter Connexion au r‚seau local* 2:
   Connection-specific DNS Suffix  . :
   Physical Address. . . . . . . . . : 1A-E3-47-70-4F-B3
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 0C-54-A5-17-E1-EE
   Link-local IPv6 Address . . . . . : fe80::b0ca:a924:93dd:5809%3(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
   Lease Obtained. . . . . . . . . . : jeudi 29 octobre 2015 19:46:15
   Lease Expires . . . . . . . . . . : mercredi 4 novembre 2015 00:42:13
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 151803045
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-95-B8-18-0C-54-A5-17-E1-EE
   DNS Servers . . . . . . . . . . . : 192.168.1.1
Ethernet adapter Ethernet 2:
   Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
   Physical Address. . . . . . . . . : 00-50-56-C0-00-01
   Link-local IPv6 Address . . . . . : fe80::987f:b77c:d5c6:2a24%10(Preferred)
   Autoconfiguration IPv4 Address. . : 169.254.42.36(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   DHCPv6 IAID . . . . . . . . . . . : 117461078
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet adapter Ethernet 3:
   Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
   Physical Address. . . . . . . . . : 00-50-56-C0-00-08
   Link-local IPv6 Address . . . . . : fe80::ccac:3ce6:650d:714f%2(Preferred)
   Autoconfiguration IPv4 Address. . : 169.254.113.79(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 33574998
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Wireless LAN adapter Wi-Fi:
   Description . . . . . . . . . . . : Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter
   Physical Address. . . . . . . . . : 28-E3-47-70-4F-B3
Tunnel adapter isatap.{21944C3C-7A1C-445D-BD2D-BCD7ADD0FFD3}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.{14CF5FC5-A073-43DB-A6B3-AFC3F367B876}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{E88D65F2-53F9-4EDC-945D-A471E0C2E6E0}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Pinging yahoo.com [206.190.36.45] with 32 bytes of data:
Reply from 206.190.36.45: bytes=32 time=195ms TTL=38
Reply from 206.190.36.45: bytes=32 time=189ms TTL=38
Ping statistics for 206.190.36.45:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 189ms, Maximum = 195ms, Average = 192ms
    AutoConfigProxy    REG_SZ    wininet.dll
    MigrateProxy    REG_DWORD    0x1
    ProxyEnable    REG_DWORD    0x0
    ProxyOverride    REG_SZ    <local>
    windows 8.1
