WLAN in Control Panel but not in system tray WLAN list
    I am setting up a new wireless router and new laptop.
    The laptop sees the WLAN (name) in Control Panel -> Networking -> Sharing and Network, but this WLAN (name) does not show up in the laptop's 'WLAN selector list' when I click on the network icon that's in the system tray.
    I hope my description, above, makes sense. If so, does this problem description suggest an area of configuration that I have done incorrectly?
    Thanks for any hints.
    Central IL
    Linux Mint 17.2
    The new router needs to be setup with the SSID not hidden. Also the router needs to be set for the same type of wireless that the devices use.
    It is also helpful when you post these kind of questions, to include system info in your profile and also manufacture and model of the router.
    broe23, sorry for the tardy response!
    Thanks very much for the reply!
WLAN Autoconfig
So, today after windows forcefully updated my pc to 8.1 from 8, my wireless doesnt work anymore. I went to services and WLAN autoconfig says its stopping but it wont stop. I tried to change the settings from automatic to disabled but it stays at "stopping" either way.
Network & Sharing
Test software for LAN/WLAN speed?
I want to measure the speed of LAN vs WLAN on my Dell XPS 15 (W 8.1). It's clear that my Gigabit-LAN is faster than wifi, but by how much? I use LAN at home, and WLAN when I'm away. Does a program exist to compare the two? PS It takes quite long before the computer "sees" the "new" LAN...
Network & Sharing
WLAN Driver immediately re-installs its self.
Hello! I occasionally come across a problem I'm incapable of solving, and when I do, Google saves the day. Not this time, unfortunately it seems no one but me has had this problem so my hopes are pretty low. Here it goes anyway. About a month ago I put windows 8.1 on my HP laptop. Like usual...
Drivers & Hardware
WLAN Extensibility Module has failed to start.
So I have bought a new wireless adapter as my old one had very poor strength and I am really impressed with the signal on this one but after a while it disconnects and then it says there are no available connections. I have to restart the adapter to get it to work again. If I am gaming online...
High latency when WLAN is on
Hey folks :) I've run into a strange something, which I can't find any explanation for. Whenever I turn on WLAN in my router, the whole network suffers from an incredible latency. No online game is playable, but the download speed itself is not being touched (i.e. fullspeed) and websites load...
Network & Sharing
Freeze with wlan-card disabled/enabled
Computer: Samsung 530U, NP530U3C-A07SE So we got this computer brand new with Windows 7. We wanted Windows 8, and performed an clean install of Windows 8, manually formatting the partitions, meaning deleting of every recovery partitions and so on. W8 booted fine, and everything worked fine,...
Network & Sharing
Baffling problem: Windows 8/lan can't see Win7/wlan
I have a Windows 8 computer and a Windows 7 computer. the Win8 is the primary computer, and the Win7 hasthe printer hooked up to it. Before they could see each other perfectly fine, but now they can't, and they can't even see each other's homegroups (I alternated leaving and trying to join on both...
Network & Sharing
