How To Make LAN Connection At My Laptop and WiFi Problem
    well i already use a program From Baid*
    i want to play game with friend, so they connect their laptop to my WiFi from a Program
    they laptop shows it already connected, so they launch the game and create a room at Multiplayer,
    well i have 2 friend so we have 3 laptops here, included mine
    my friends can join the room that my other friends create, but when i trying to find the room i can't find it, why?
    my friend can join the room but why i can't join it acctually i can't find the room, i think it's weird because it was my WiFi
    so why only me that cannot find the room?
    Then i hear i can make my own WiFi without any program to share like LAN connection from laptop? can anybody help me or guide me to make it?
    ah and there another problem,
    at my school i connect my laptop to my school WiFi
    it connected but i can't browse anything because there's no connection
    maybe the adapter is broken because i change it because i want to test my game last night
    someone please help me
    Austin TX metro area
    While I used Windows 8 [before rolling to W7Pro], I noticed that sometimes I was "connected," but there was no "interneting." For troubleshooting, I would dial back some of my security [antivirus, antimalware, antispyware] settings -- not to "Zero" [no proection], simply from moderate to light protection [i.e. Windows Firewall & MSE] -- and test. Once successfully "interneting," I would slowly bring back my normal security settings, testing from time to time. The regular w8f-techs will be along sooner or later to offer advice. Programs like Bitdefender, Avast, AVG, etc. can be too-assertively set, check those settings if you use any one of those blockbusters.
Internet connection problem throug Laptop Network port
Hi All, at my home, i got internet connection from coaxial to my modem.. i had tried couple time to hug up internet from Modem through Wan port to my laptop network port by RJ-45 but the internet status said not working(yellow sign at the network icon on task bar". I tried 3 of my laptops,...
Network & Sharing
Slow wifi connection - Adapter problem or Windows 8?
I just bought a new computer and it has a wireless adapter already plugged in the USB internally. It is a Realtek RTL8811AU Network Adapter. I am running off wifi on other devices in my home right now and the connection is perfect for those. When reading the reviews for my computer, which is this...
Network & Sharing
Windows 8 laptop limited wifi connection
Can't connect after windows update. Have tried everything to connect to home wifi. Reset EVERYTHING. Uninstalled and reinstalled wifi driver. Used system restore to roll back updates by windows. Followed sugestions on this forum and others. Flushed DNS. Tried to reset TCP/IP stack but failed access...
Network & Sharing
How will I make my internet connection work normaly?
Hey guys! Im not so good with computers, and I could really use all the help with my problem. I keep disconnecting every 3-4 minutes, but only for some seconds. the internet icon always keeps showing that I have internet. I tryed using an other cable but it the problem is still there. It...
Network & Sharing
Network Wifi Connection Problem
Hi, So The Problem is that i changed my SSID on my router because i have created a hotspot by mistake with a same SSID of my router Wich is named DJAWEB and it was annoying so i changed my router`s SSID To Djaweb it worked fine but i still see the other SSID (DJAWEB) of my computer hot spot and i...
Network & Sharing
no wifi connection?
My windows 8 won't connect to my wireless at home but will connect everywhere else. It tells me that my ip needs configuration and that the media is disable on my networks among 100000 other problems that are apparently stopping me from connecting properly, but wouldn't that mean that this problem...
Network & Sharing
no wifi connection what do i do?
I have no idea what to do i know it is about drivers but i cant connect to the internet at all can someone please help me!:cry:
Network & Sharing
