HOMEGROUP & NETWORKING Problem
Kenny Burke
Hi All
I am new to this forum and really hope you can help me out. I have purchased two new computers which are running windows 8.1. My Problem is I cannot get them to network. I have carried out all recommendations for setting up a homegroup, but to no avail.
Please Help!
Kenny.
Firewall and/or Internet Security software is the usual culprit. They have to be on the same router also. Homegroup only shares Libraries. If you want to share just a specific folder, use regular Network Sharing.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
Hi Broe23, thanks for your reply.
I am using Windows firewall and the only other security software installed is Avast Free anti-virus. I have disabled both of these, but it didnt help. I have also tried sharing a specific folder, but again to no avail. Both pcs are on the same router and have the same workgroup.
My other two XP pcs are still up and running whilst I complete the upgrade and these are networking fine.
I should also mention that the windows 8 pcs are connected to the wifi router and work perfectly online!
Homegroup has been known to screw up on its own from a security fix from Microsoft/Windows update. I personally do not like to use it, because it is very limited in what you can share and how you can share.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
Disable home group, set up your peer to peer network as you always have in the past. I share to Authorized users only. Put the same user Name and password on all computers. Window 8 will resist but in the end networking is no different that it ever was I also set my router to assign specific IP addresses to each computer
    Windows 8.1 Pro MC
    Asus G75VW / Z97 Pro
    Intel Core i7-3610QM / I7-4790K
    Z97 Pro
    16 GB Hyundai HTM315156CFR8C-PB PC3-12800
    nVIDIA GeForce GTX 670M (GF114M)
    VIA 6.0.10.1600
    Samsung 850 Pro 256, Samsung 850 Pro 1TB
    30 down 3 up
    Explorer 11
    NIS and Malwarebytes
I've tried setting up a peer to peer network, but the computers just won't talk to each other! Today I purchased a new wireless printer and again this won't talk to the computers. I've disabled windows firewall and avast AV, but this still makes no difference. Could this be an issue with my router? I'm thinking of resetting the router to factory settings on Monday morning to see if that makes a difference.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
There is also the help guide at EZLAN.NET
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
