Weird Connection Problems - Help Needed
  1. #11
    No change from what I can see here. Have you done any virus scan's lately?
    Which anti virus software is installed on this machine?
  2. #12
    Sorry for not being patient. Bump.
  3. #13
    She says she has none.
  4. #14
    Did you run the rest file?
    It's required that you answer the questions and confirm things here.
  5. #15
  6. #16
    We are just going to save everything important and restore factory settings. I appreciate you guys trying to help though. Thanks.
  7. #17
    have you tryed opening the cmd and typeing in ipconfig /flushdns
    If this does not working try right clicking on the network icon on the bottom right and open network and sharing center click change adapter setings right click on the device you are useing and click properites go down to ipv4(Internet protocol version 4) and click properites and see if it is defined auto or not
Page 2 of 2 FirstFirst 12
Some weird problems lately
sfc /scannow = No problems Dism = No problems System fully updated RAM diagnostic and Checkdsk come up clean. Problem 1: "Invalid Registry Entry" error when opening files: Has happened with mp4's and PDFs so far. Reboot or login/out fixes it temporarily. My PC is on 24/7 so it will...
Network Connection Problems
A couple of days ago when I opened IE I got an error message saying I was not connected to a network. I was, with internet access, and I knew this was okay as my partner was sitting 3 feet away using the internet on his machine. I eventually resolved the issue by doing a System Restore but the same...
Network & Sharing
Windows username and Skype weird-might-be problems
Hello. About a month ago I saw for the first time the username system on Windows 8. I have never created as much I remember a username in my computer. However, suddenly this new thing popped before my eyes. But it was'nt a request or something reasonable that Windows noted me. It claimed that my...
System Security
Windows 8.1 weird problems, anyone able to offer advice?
Okay so my laptop is a Toshiba Satellite C55D-A-13U, runs Windows 8.1 and has some serious issues. It's a month old and has 8GB of RAM, AMD A6-5200 APU, Radeon HD Graphics and 1TB hard drive. And also it barely works at all, which just doesn't make any sense. My problem is that when I'm on the...
Performance & Maintenance
Weird problems after restoring Windows 8
Hello, I had some heating problems with my laptop and it turned out that it is the hard disk and I had to replace it. To keep my configured Windows and all applications I have made a backup which I installed on the new hard drive. Now I have some issues with my Windows that I can't resolve -...
Browser Connection Problems
Hi guys, I have just upgraded from Windows 7 Home Premium to Windows 8 Pro and am extremely frustrated with my browser connection. I say browser rather than internet as that seems to be running fine with feeds on the start screen and uploads/downloads continuing in the background with no issues...
Browsers & Mail
Internet connection problems
Hello, Firstly I'm no computer expert atall so I might be showing my ignorance here. I've just got a Sony Vaio with windows 8 which initially worked ok, but now won't connect to the internet atall, either with the ethernet cable or on wi-fi. Windows diagnosis does nothing. It was working...
Network & Sharing
