I've installed Win8 to my laptop and tried to connect to our dormitory network. First, it has been working pretty well.. ..but since this morning*) I cant connect. The troubleshooter ends without success displaying: "Wired ehernet connection doesnt have valid IP configuration."
I'm quite "greenhorn" in deeper settings but I did my best and nothing have worked.
I found out interesting Network Connection Details of Wired Ethernet Connection Status:
Connection-specific DNS Suffix:
Description: Broadcom NetLink (TM) Gigabit Ethernet
Physical Address: 00-1F-16-C5-CC-AA
DHCP Enabled: Yes
IPv4 Address:
IPv4 Default Gateway:
IPv4 DNS Server:
IPv4 WINS Server:
NetBIOS over Tcpip Enabled: No
(Note: I have set "Obtain an IP adress automatically" as it was required by our administrator.)
I would be very grateful for any help. If you'll want any details, please dont hasitate to ask..
Thanks in advance
D.
*) administrators have uptaded their "device list" (or somethink like that - the list of users and details about them) and since that my laptop cant find the network. But my records are ok, I've checked that.
Thanks in advance
D.
My ethernet port isn't working either. In my Device Manager, Ethernet Controller and 3x Base System Device's are yellow flagged. Doesn't seem good!
OS Windows 8 developer preview x64 / Mandriva 2011/ Windows 7 x64 Ulitmate CPU AMD Athlon x2 (2.70 Ghz) Motherboard Asus M3N-HD/HDMI Memory 5Gb Graphics Card Asus ENGTS250 (512mb) DK Sound Card (some realtek one.. google my mb for detailed info...) Monitor(s) Displays 2 19'' LG flatron wide 16:10 Screen Resolution 1440 x 900 (16:10)
Keyboard Logitech G19 Mouse Microsoft Sidewinder x3 PSU Antec 500W Case Antec three hundred Cooling 3 fans + psu and cpu + gpu Hard Drives 1x Samsung 500 Gb
1x Samsung 30 Gb
1x LaCie 1Tb Hard drive. Internet Speed 110mb/ s Other Info 7 years old one
1x Samsung 30 Gb
I am also in the "greenhorn" category, other than plug in and go. But, for curiosity, do you not have a wireless card in the laptop? If so, maybe there is a conlfliction. Try disabling the ethernet card and going wireless.
So..
- my etherned card is build to MB (at least I hope so - I use Acer Aspire 5738g)
- wifi connection works great. But I need to connect via ethernet cable 'couse I've paid for that..
Yes, I've disable wireless connection before I've tried to connect via ethernet cable. ('cause it is on our network's manual.. Unfortunatelly, there is not a manual directly for Win8 connection)
