Windows 8 Forums
Results 11 to 20 of 22
  1. #11
    zigzag3143's Avatar
    Wanikiya & Dyami
    Array
    WCP
    Micronesia
    If there is a yellow flag in device manager the driver isnt working properly. If I were you I would re-install the most recent version
  2. #12
    Junior Member
    I went to the Asus website and the drivers for my ethernet port (JMICRON LAN DRIVERS) will not run. An error message pops up that says: Fail to Call ProcInitSetupArg!
    I tried looking for updates through the device manager, but it doesn't find any.
  3. #13
    zigzag3143's Avatar
    Wanikiya & Dyami
    Array
    WCP
    Micronesia
    Quote Originally Posted by mylastresort View Post
    There is obviously a problem with the system. You could try to do a repair install to fix the problem files. There is a tutorial on how to do that here in the tutorial section.
  4. #14
    Junior Member
    Quote Originally Posted by zigzag3143 View Post
    I did the repair install, and it is still having the same problem.
  5. #15
    Kynix's Avatar
    What is this?
    Helsinki
    Windows 8 developer preview x64 / Mandriva 2011/ Windows 7 x64 Ulitmate
    Finland
    Does your BIOS find the ethernet card?
  6. #16
    Junior Member
    Sorry, how do I figure that out? In my device manager the Ethernet Controller appears with a yellow flag, is that what you mean?
  7. #17
    Junior Member
    Win8Beta
    USA us california
    Have you tried uninstalling it or rolling the driver back?
  8. #18
    Junior Member
    I uninstalled the driver
    manually installed the drivers from Asus' support site
    Manually updated the driver in the device manager by locating the files I just installed
    success it's fixed. thank you.
    Any idea what the Base System Device's are though? I don't know which drivers to install for those
  9. #19
    Kynix's Avatar
    What is this?
    Helsinki
    Finland
    Usually those are downloaded by Windows. Those are the drivers, that you can install by downloading the newest chipset.
  10. #20
    chev65's Avatar
    Senior Member
    Windows 8 WCP
    My wired connection did the same thing this morning. Said Unidentified network. Ran the trouble shooter which fixed it. After reboot it's working again.
Solved Problem wtih Ethernet Controller - No Internet Hardware & Drivers
.net 3.0 problem Installation & Setup
Is there a problem with SF??? Chillout Room
unreliable server2008 connection Network & Sharing
