Wierd networking problem
Kuall
I am running a Sony Viao SVE171E13M laptop with Win 8.1 through a BT Infinity hub. The computer connects to the internet just fine when running through the desktop programmes such as Firefox, Steam and Windows Live Mail.
However none of the Metro apps work and Store states that I am not connected to the internet. In addition I can not set up a homenetwork, again apparently as I am not connected to the internet.
When I use my phone as a hotspot, these things work fine, but 3G is not great for more than a last resort.
I am running a BT infinity hub, through power line wireless extenders, but have tried through the hub only and Metro still doesn't seem to see the wireless network.
I am quite tech savvy, but not an ubergeek, any help would be greatly appreciated, and i should be able to follow simple advice.
I can use the computer but am not getting any benefit from Win8.
Thanks
Alex
    Sony Vaio
    McAfee
    Windows 7 x64/ Windows 8.1 x64
    Self Made
    Intel i5 2500K @ 3.3GHz
    Asus Z68 V Pro
    16GB DDR 3
    HIS 6870 ICEq edition
    Samsung 22" Display
    WD 1 TB
    Seagate 2 TB
    WD 320 GB
    coolermaster 750 W
    Coolermaster HAF 912
    TVS Gold
    Samsumg
    4 Mbps
    AVG 2013 IS
Thanks
Alex
So many reasons why this can happen, this is a weak point in Windows 8 for certain.
http://www.eightforums.com/tutorials/21051-apps-tiles-not-working-responding-fix-windows-8-a.html
http://www.eightforums.com/tutorial...apps-troubleshooter-fix-apps-windows-8-a.html
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Thanks guys, I am just running DISM and ill see if it helps. I have tried the windows troubleshooters before with no luck. I'll try the links above and let you know how it goes.
    Sony Vaio
    McAfee
Thanks for the responses guys, I wasn't able to look into it for a few weeks but I am still not able to access "store" or other metro apps.
I run a bunch of trouble shooters and the DISM mentioned above, but no luck.
Has anyone else come across this issue and how did they fix it?
    Sony Vaio
    McAfee
You really need to run the sfc /scannow command first before the DISM command.
This will fix the system files and should help DISM complete it's task.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Thanks,
I have ran scannow in the past, but I will run it this time, then DISM and see what happens.
    Sony Vaio
    McAfee
Right,
I ran scannow, then DISM then scannow again, restarting the laptop after each operation.
Still the same problems, i did get a CBS log from the second scannow, which stated that some corrupted files weren't fixed. Strangely the first run didn't mention the corrupted files.
I can attach the txt file or PM to someone who knows what he's/she's looking far.
Thanks for the help so far.
for info the error message when opening up the store is "We weren't able to connect to the Store.This might have happened because of a server problem or the network connection timed out.Please wait a few minutes and try again. (0x80072efd)
Cheers.
K
    Sony Vaio
    McAfee
Right,
Cheers.
K
Run both scans again rebooting after, it sometimes takes 3 complete scans to fix these problems.
Until those scans come up clean there is no chance anything will be working right.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Apologies about this.
I have run scannow and DISM several times now, rebooting in between. I still can't get on the store, and home group states that I'm not connected to a network, and I can't select a network because apparently I am on public/guest settings. This is all very frustrating.
I don't want to restore the laptop and I can be bothered to find all the data again.
    Sony Vaio
    McAfee
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
