ralink wireless lan card problem
    i have an asus desktop.after the windows update i've lost my wifi says that the windows cannot install the router is checked.i try to download the drivers directly from asus but the problem still. i dont know what to do anymore.
    Sloe Deth, Californicatia
    Try doing a system restore back to before you downloaded the downdates that messed you up, then refrain from downloading any RAlink drivers in the future unless they come FROM Ralink.
Upgrading intel wireless card
I have a refurbished Lenovo Y40 and I am happy with everything except the wireless card. It is an intel ac-3160 card but right out of the box it had many problems. Internet signal drops off significantly when I am more than 5 feet away from the router. I know this is normal but my computer's...
Network & Sharing
An old 3COM Wireless PCI card
Hello! I upgraded from Windows XP to Windows 8.1 (x86) an older desktop PC (Lenovo ThinkCentre) and everything works excellent. Except one thing - an old wireless PCI card (it worked fine in Windows XP). It's driver got installed with the Windows Update (there's no Windows 8.1 driver for it...
Drivers & Hardware
ralink wireless won't work
I have just upgraded from windows 7 ultimate to 8.1 but I can't seem to find any driver that works for my ralink wireless it is 802.11 n wireless LAN card. I have uninstalled it I have updated the driver but it still won't work can someone please give me some advise on how to fix this. Thanks...
wireless card goes to sleep
I leave my laptop on at night to capture updates etc. On my new HP Envy with win 8.1 by morning the wireless card seems to have gone to sleep and the signal strength icon is grayed out. The pci power settings are "OFF" and the power setting in Device manager are also set to NOT turn it off. ...
Performance & Maintenance
Not sure if my wireless card driver is updated or not
I upgraded to Windows 8 Pro and supposedly I installed all the Windows 8 drivers I got from my laptop's manufacture website (Sony) but when I go to device manager in control panel my wireless card has the yellow exclamation mark and in the properties it says that no driver update is installed even...
Drivers & Hardware
Ralink RT61 wireless card driver problem
I have driver for this device, when i try to update it it starts instaling but then i get info that windows can't find file (image 1)... I tried to disconect card from motherboard and connect it to another slot, i installed devide again and then i tried to update it but i get the same...
Drivers & Hardware
Wireless card issue
I have a realtek 8188ce built into my Toshiba laptop. Initially windows 8 detects it and it works fine, however after a restart (or 2) the device manager will report that the device cannot start or simply wont detect the wireless card at all. I've also downloaded the latest drivers from realtek and...
Drivers & Hardware
