Networking Problems (Unidentified Network)
al4nw31
Tried EVERYTHING.
Have an identical setup to my dad, except I have a GTX 660 Ti.
I have TWO identical computers, so ask me questions (both custom built).
So here's the LOOOOOOOOOOOONG story short.
Internet has been having issues lately, getting unidentified network on one computer.
Problem is, I have an IDENTICALLY built computer with no problems.
Here are the specs that matter:
GA-Z77X-UD3H Motherboard (on both)
i5-3570K (if that matters)
Both are using the AR8161 Atheros LAN chip
One is getting unidentified network.
Software fixes have gotten me nowhere.
So there are two things that could be screwing it up.
1) Pando Media Booster
Installed as my first application, installed along with League of Legends.
2) Bonjour
Installed along with iTunes.
I don't know which is the culprit, and what is the problem, and how to fix it.
I've tried fixing it, and there is no possible fix within my knowledge.
It's been three weeks or so since the internet was working fine.
I've since replaced my computer, my router, and my modem.
All of them resulted in no fix. So I've busted around a grand with nothing to show for it.
My parents are a bit edgy because of that.
I have a NetGear R4500 (identical to WNDR4500), a SB6121 Cable Modem, and the chipset named above.
My dad also has iTunes installed with zero problems, leading me to believe that Pando Media Booster may be the culprit of this.
I get the errors:
1) 'Ethernet' does not have a valid gateway IP (or along those lines).
2) Some DHCP error, forget the exact line.
I've attempted uninstalling and reinstalling the driver of the Atheros chip, yet I accidentally tried shutting it off in the middle, and now it's stuck on "Windows is uninstalling the driver of this device. (Code 21)", on the device manager.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Corsair Vengeance 4x4GB
    Gigabyte nVidia GTX 660 Ti
    Samsung LED
    2TB Western Digital Caviar Green
    XFX PRO750W 80Plus Silver
    Fractal R4
    Stock Fan :3
    Microsoft Keyboard 5000
    Logitech G9x
    ~30Mbits
I hate to suggest a search, but I think that the unidentified network thing has a variety of sources. So, how about googling on unidentified network? And, you could try unidentified network Windows 8. I hope you find your solution. This issue often is difficult to resolve.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
Tried EVERYTHING.
2) Bonjour
I get the errors:
The Bonjour problem can go either way, sometimes it wrecks havoc on Windows systems, other times it causes no problem.
Since it doesn't really do anything it's best to uninstall it because it's actually famous for causing the Unidentified Network problem.
Pretty much any secondary network interface can also cause this problem to occur so it's best to disable any secondary network interfaces until the problem is solved.
Other possible causes of this problem are covered in the link below, there is also good info in the comments section in the link.
If you can post a screen shot of the ipconfig/all from this machine it would be helpful. :)
Windows 7 Unidentified Network, Limited Access, No Internet Connection Problem Resolved
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Windows IP Configuration
Host Name . . . . . . . . . . . . : AlanComp
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Qualcomm Atheros AR8161 PCI-E Gigabit Eth
ernet Controller (NDIS 6.30)
Physical Address. . . . . . . . . : 90-2B-34-5C-AC-37
Link-local IPv6 Address . . . . . : fe80::9115:8706:3a08:ab81%14(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.171.129(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 210774836
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-72-9E-C6-90-2B-34-5C-AC-37
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{750847DC-C6ED-4D90-9AA3-66F52A35BC80}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Here is the ipconfig, thanks.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
Oh yeah, at times the Internet will just work, and other times it won't.
Like I will sometimes start it up and it will be working then all of a sudden the Internet will just die and won't work for up to like days.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
Have you tried another cable from your PC to the router ?
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Try uninstalling league of legends, panda and bonjour, is there a third party anti virus or firewall installed?
You may need to reinstall them one at a time then test for connectivity over a period of time.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
I have uninstalled Pando and Bonjour as of now, still having connectivity issues.
I will try uninstalling League of Legends now.
There are no third party antiviruses or firewalls installed.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
Have you tried the Gigabyte website for the latest drivers and bios updates?
I'm sure you have been to Windows update center?
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Yup. I updated my network drivers to no avail (except a 10 minute window where I could access the internet).
Should I try the BIOS update?
Because this was happening on my old computer, but none of the new computers or other devices were affected.
Only MY new computer is affected >.<.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
Anyone?
Here's the ipconfig /all when the internet IS working.
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Lease Obtained. . . . . . . . . . : Thursday, January 3, 2013 6:47:13 PM
Lease Expires . . . . . . . . . . : Friday, January 4, 2013 6:47:13 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:28f7:309b:b381:2d9b(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::28f7:309b:b381:2d9b%12(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
Every looks normal here, I can't imaging why your connection is going off and on again but it's certainly not normal.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
I cannot yet fully update the computer until the Internet works for an extended amount of time >.<.
(from windows update)
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
Yes that would present some problems for Windows update.
It's near impossible to diagnose problems which are intermittent, but normally going to the board manufacture's web site and obtaining the latest drivers and bios updates is good course of action though you may need to use another machine to download the updates.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
How is it that my dad's computer is alright when mine isn't though?
I just really do not understand that part.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
How about trying a system restore back to before the problem began. If you have no luck, then you could try a system refresh or a system reset
    EVGA 570 SC
    Gateway
    Dual Boot:
Yes that is strange, it seems that somehow the 660Ti is the only difference between the two machines so maybe try another graphics card and see if anything changes.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
I had an old PC that I thought the mobo was bad, which had the problem, and since the chipset was no longer in production, I built a new PC.
Which has the same problem as the old one...
Upon formatting my drive, the same problem was occurring.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
There were only two parts that I reused from my old system. My 2tb caviar green (WD), and my 660ti. I'm going to try and take the 660ti out and just use built in graphics.
    Custom Built
    i5-3570K
    GA-Z77X-UD3H
    Samsung LED
    Fractal R4
    Stock Fan :3
    Logitech G9x
    ~30Mbits
