Which version are you trying? Are you installing on a separate partition? Do you have Norton AV installed? if you have, remove it and see whether it helps.
win 8 pro x 64
i tried to install clean on a single partition hard drive bt it failed jus after saying checkin for hardrware after all the installion process is complete
