factory reset problem
    Sorry for any errors. Typing on my phone.
    So I installed a graphics card a few months ago. Today i decided to factory restore my computer. I've plugged in my old integrated card but it's not displaying. I did upgrade to windows 10. So i don't know if that might have something to do with it or if the computer is still driving get drivers working. Hope this makes sense. Thanks for any help.
    Hey Mate,
    In my experience, if you put a card in the PCIe slot, it will usually be the default after that. Try plugging the monitor cable into the new card you installed, it should run just off the stock VGA driver in windows. Otherwise, on some MB's you can go into the BIOS and select the default port. If that fails, remove the new Graphics card, perform the factory reset again, and then install it after putting on windows 10 again.
    Hope that helps.
To-do before factory reset???
So I've purchased a new laptop that has never performed well. HP wants to do a remote wipe & factory reset. I need to save all my files, bookmarks, settings, etc. before we do this. Feel free to talk to me like I don't know what I'm doing, because essentially I don't. :) How do I back up...
No signal after factory reset
So I did a factory reset on my pc, came back into the room to see that my monitor (tv) said no signal and my small LG monitor was black so I just assumed it was part of the process. After about 6 to 7 hours of waiting it still remained the same, even after restarting and trying many other methods...
Can't Reset to Factory Settings
Hello, I have a HP Envy x2, which I purchased refurbished with Windows 8 pre-installed. After I upgraded to Windows 8.1, I starter to notice many problems such as; the tablet wouldn't start all the time, the secure boot was disabled (but I fixed that), the app store doesn't work all the time, and...
Installation & Setup
How to do a factory reset of Windows 8.1?
So I installed Windows 8 whenever it came out and then updated to 8.1 last fall. Since then my computer has become bogged down and running really bad. It's time just start fresh but when I go in to the PC settings to restore it, it says I don't have the necessary files and that I need to insert a...
how can I do a factory reset
I purchased a Samsung ATIV One 7 27" Windows 8 All-In-One Computer (DP700A7D-X01US) | Samsung PCs from best was a demo on the shelf I did a copy with paragon to a ssd. it runs great but it seems to missing something's about it. how can I do a factory reset. If I do a recovery will it just...
windows 8 factory reset problem
need some help with a factory reset on windows 8. my son decided to reset his windows 8 laptop to original factory settings, during the reset process his mom decided it was taking to long and turned off the laptop. now when its turned on it shows the message "restoring your computer", this...
Factory Reset Win 8 without Disc
I upped from 7 to 8 via OTA download. Set up, set up passord(admin), etc. and decided I didn't like and want to do a Factory reset so I can sell. I did the microsoft $39.95 special, and hve no disc. Can I factory reset, and how please. Many thanks, Bob
