users/settings on diffrent drive to os, problems reseting
    When I originally set up my PC with a clean install of windows 8.0, I installed the operating system on the C drive (my SSD) and users/settings on drive E (an HDD)
    it seemed like a good idea at the time.
    When the windows 8.1 upgrade came out, I ran into an error due to my foolishness, and honestly, never tried to fix it.
    More recently I have missed out on a few driver updates for my graphics card, and with windows 10 around the corner, it seems like the time to pull my finger out.
    I have been trying to format, or reset, my PC with a fresh install of Windows so the users and settings are on the C drive with the operating system, so I can upgrade to 8.1. Each time I try through PC settings, or booting off my Windows 8 disk (64 bit OEM) Windows tells me it has failed, without giving any further information than that. There is no error message I can Google.
    If anyone has come across something similar and knows a solution, Id really appreciate a hand. If not Ill have to take it into a repair shop at some point.
    Thank you
    Managed to find a fix.
    I fully formatted E through windows explorer. This left a windows install with no user directory, so an empty blue task bar at the bottom of a black screen. I then booted off the dvd and reinstalled Windows. On Windows 8.1 now, and it all seems to be working properly.
Prevent MS Account users changing settings /w gpedit.msc
Hi, I have Acer Aspire Switch 10 as public test computer for people and they can login using their Microsoft Account. Some people mess up the computer on purpose to do mischief and I had to use System Restore to fix things few times already. Is it possible to use gpedit.msc to prevent users...
User Accounts and Family Safety
Set large DPI settings for all domain users
Heya, I have an HP Compaq Elite 8300 with a very bare-bones install of 8.1 Enterprise. We have it connected to a 75" Samsung Smart TV and is used to give presentations in a boardroom-type setting. What i am trying to do is set the DPI settings for all users to 150% Whether they have logged in or...
Reseting my Computer back to factorysettings
First of, i apology for my bad english, im from germany :/ I have a problem with my computer. I completely rushed with installing all the programs as i first got it. I completely made the wrong programs in the wrong files and so on. Now my computer is very slow, i have many programs i wish i never...
Installation & Setup
Can I alter other users power settings through regedit?
I'm have admin rights on a laptop, another user does not so they can't change power settings. Can I alter the power settings on their account through regedit...specifically I want to alter the behaviour of the laptop when closing the lid. Does anyone know a way of doing this? Jamie
Performance & Maintenance
Problems Syncing Settings
Hi all, Since this is the last thread I could find about syncing I post my problem here. Last Friday I received my pro 3 i7 and I am very happy with it because it is just an awesome machine and a big step higher then the rt, surface 2, pro and pro 2 I own(ed). I am a happy camper that I could...
Drivers & Hardware
HELP-Reseting Factory Settings DELL Inspiron 660s-Windows
I'm becoming so frustrated in trying to reset to factory settings my Dell Inspiron 660s that uses Windows 8. Some how my ex had downloaded a interface to make Windows 8 look like windows 7. It has virus on it that I just want to reset it. I have tried to reset thru going thru change pc...
Users link under PC settings dissappeared!
Hello everyone! Just faced a problem where my "users" link under PC settings have just completely dissapeared... Also when i got to: "Control Panel\User Accounts and Family Safety\User Accounts" i see the links: Change your account type Manage another account Change user account control...
