Will Leedham
Hi,
When I originally set up my PC with a clean install of windows 8.0, I installed the operating system on the C drive (my SSD) and users/settings on drive E (an HDD)
… it seemed like a good idea at the time.
When the windows 8.1 upgrade came out, I ran into an error due to my foolishness, and honestly, never tried to fix it.
More recently I have missed out on a few driver updates for my graphics card, and with windows 10 around the corner, it seems like the time to pull my finger out.
I have been trying to format, or reset, my PC with a fresh install of Windows so the users and settings are on the C drive with the operating system, so I can upgrade to 8.1. Each time I try through PC settings, or booting off my Windows 8 disk (64 bit OEM) Windows tells me it has failed, without giving any further information than that. There is no error message I can Google.
If anyone has come across something similar and knows a solution, I’d really appreciate a hand. If not I’ll have to take it into a repair shop at some point.
Thank you
Thank you
- 8.0
- Computer type
- PC/Desktop
