Solved 8.1 pro volume license key fails when installing from USB
speedlever
I have a Vostro laptop running Win 7 pro x86. I want to upgrade it to Win 8.1 pro x64 and have a volume license key. The optical drive on the laptop is broken so I need to install from a USB stick. I created a bootable USB drive from here:
Create installation media for Windows 8.1 - Windows Help
The laptop boots from the stick, but when I input my license key, a message pops up saying it can't verify the product key.... please check your installation media. I have the laptop connected via ethernet cable, so I don't believe it's a connection issue.
Is installing from a USB stick not supported for a volume license key?
    Windows 8.1x64 pro
    Homebrew
    i5-2500k
    Asus P8Z68-V Pro
    16 GB
    2x 19 inch
    1280x1024
    256 GB SSD
    1.5GB
    2 GB
    3GB external
    Antec Solo
    Avast free
Windows 8.1 Pro Volume License with Update (x64) - MSDN ISO [November 2014 Rollup]
File Name: en_windows_8.1_pro_vl_with_update_x64_dvd_6050880.iso
Languages: English
SHA1: 962A1D890987B5877469433928B8C8B8A3E945CD
    Windows 10
    Lenovo G580
    Intel Core i5-3230M
    8 GB
    Intel HD Graphics 4000
    Microsoft Edge
    Windows Defender, standard user account
    UEFI firmware (BIOS) embedded Windows 8 product key.
The last time I messed around with VL, I could swap keys on retail media... things may have changed subsequently - need to do a quick VM test. Assume it's a Professional Volume:MAK key.
    PC-DOS v1.0
    IBM
    Intel 8088, 4.77MHz
    16K, 640K max
    What's that?
    Not quite
    80 X 24 text
Yes, I have the Win8.1 x64 ISO file. I tried the Windows USB/DVD download tool:
Windows USB/DVD Download Tool - Microsoft Store
but it failed with an error message something like:
unable to run bootsect to make the usb bootable
This on both a Win 8.1 pro x64 and a Win 7pro x64 computer.
Now I'm trying a tool called Rufus: (I found over in Sevenforums)
Windows 7 USB/DVD Tool - "unable to run bootsect" - Windows 7 Help Forums
https://rufus.akeo.ie/
It created the bootable USB drive without issue. I'll find out shortly if it works.
Edit: Plugged in the USB drive, rebooted the laptop and chose the USB drive to boot from and it works great!
    Windows 8.1x64 pro
    Homebrew
    i5-2500k
    Asus P8Z68-V Pro
    16 GB
    2x 19 inch
    1280x1024
    256 GB SSD
    1.5GB
    2 GB
    3GB external
    Antec Solo
    Avast free
Good to hear - FYI: seems the retail media doesn't like MAK keys - they accept GVLK's though.
    PC-DOS v1.0
    IBM
    Intel 8088, 4.77MHz
    16K, 640K max
    What's that?
    Not quite
    80 X 24 text
