Solved Installation problem
kanoj
Hi eightforums,
i'm trying to install win8 from bootable DVD into a new partition with 20GB vhd. Dual-booting it with win7, but its getting struct at "Devices getting ready 8%".
My PC Configs
please help me...
    Microsoft Windows 7 Ultimate /32bits
    Compaq-Presario SG3145IL, Model: GV436AA-ACJ SG3145IL (103C_53316J- SKU:GV436AA#ACJ)
    Intel (R) Pentium(R) Dual CPU E2140 1.60GHz
    945GCT-HM (Livermore8)
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
    Hitachi HDS721680PLA380 ATA Device
Hi,
Why bother at all with VHD in this scenario? Simply install normally to the new partition you already made. 20 GB should be fine for x64, but I'd make it at least 30-40 GB.
If installing x86, slightly less is alright. Recommend to go x86 with your hardware.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi Gman,
created new partition with 20 GB and installing it., its repeating same issue..
and thanks for reply...
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
Sure thing, you're welcome.
Is this an ASUS motherboard?
You can type msinfo32 in the Start menu then press Enter. File | save on the opened screen. In Windows Explorer now, right click the saved file and choose Send To>>>Compress (Zip) folder. Attach the zip made to a new post. Maybe there are some clues to see or something. I dunno.
Please also attach a screenshot of Disk Management of Windows 7.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi Gman,
Its getting struck whenever i save msifo32..
so i attached screenshots of system info and disk mgmt..
pls check.
Sorry for delay..
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
Format H: to NTFS quick in Disk Management.
Convert H: to a Primary partition. Use Acronis Disk Director or GParted live.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
formatted to NTFS quick.
How to convert
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
ok.. installing Acronis Disk Director
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
ok Gman,
I've converted H: to primary using Acronis Disk Director.. what shld i do next??
reply me when u r free.. coz i know i'm here in India, its 4.40 pm here.. u dr could in at 7 am..
thank you..
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
Hi,
please suggest me though...
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
Or else please tell me how to fully remove win8. whenever i start my PC, win8 installation resumes and gets struck..
(I was dying to install windows 8)
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
Set Optimized Defaults in the bios then install again while formatting the partition you are installing to.
Remove everything first from the machine that is not necessary. For example, external storage, any kind of peripherals like a gamepad etc...
Install 32 bit Windows 8.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hi Gman,
It worked!!!
I changed status as u said.. It was actually problem with logical drive. I changed it to primary and win8 is done..
Gotta check it now.. it has got new style...
Thanks a lot...
Thanks a lot eightforums!!!!
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
Cool, good deal. Glad to hear it.
You had me slightly confused above there - I thought you tried to already install again and ran into trouble again - so that's why I said to format again while installing....again...lol
Don't forget now to visit your motherboard manufacturer's website to install the chipset, storage, USB 3.0 (if exists) and any other latest drivers they have for it.
Also visit NVIDIA.com or AMD's site to get the latest video card driver to install if you have a card from one of them.
Enjoy.
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I'm onto it Gman...
Thanks again...:D
    I.50 GB RAM
    HP w17e
    1400x900x59 Hertz
