Riobonitoranch
Sirs,
I have recently built 2 new systems with the following ram:-
KINGSTONS
Beast - 32GB Kit* (4x8GB) - DDR3 1866MHz CL10 Intel XMP DIMM
Part Number: KHX18C10AT3K4/32X
Specs: DDR3, 1866MHz, CL10, 1.5V, Unbuffered, Spec Sheet PDF
Profile 1: 1866MHz, 10-11-10, 1.5V
Profile 2: 1600MHz, 9-9-9, 1.5V
System specs are both :-
Asus Sabertooth AMD3 RV 2.0
2 x 8mb sticks in each system
AMD FX9590
Thermaltake Toughpower Gold 750 Watt
Crucial 512GB SSD
WD SATA drives
PCI SCIS card for 2 x SAT & 1 x IDE
Both systems use R9 280 graphics cards, 1 is MSI & 1 is Sapphire
Windows 8.1Pro x 64 bit
Classic shell start menu installed.
Microsoft office
QuickBooks
Can’t think to mention anything else?
I am having trouble with 1 of the systems, being the one with the MSI card.
Problem being:-
Initially system was OK
This system ran fine for approx. 2 weeks, but started to have issues firstly on installing a 775mb windows update; the system wouldn't install it, would try but then rebooted saying removing changes?
Occasionally, would get locked in restarting loop, but not always.
After this point I did the “move user folders to another drive “ by Kari, ie:- http://www.eightforums.com/tutorials/4275-user-profiles-relocate-another-partition-disk.html and this ran 110%, system in fact seemed a bit better?
Then I spilt a cup coffee on keyboard, unplugged keyboard to change it out & inadvertently placed the usb connection in another lower IO panel outlet, computer didn’t like that at all, it then went downhill from there, there were many small glitches & errors on my part to the point where it slowly crashed and I ended up doing a clean re-install on the formatted SSD.
This fresh re-install was Saturday, & all went well, once I had several major windows updates installed & everything seemed to be running fine, I took 3 different COMPLETE system backups with Acronis True image 2015 & saved these images to 3 different removable drives. At this stage, everything seemed fine.
I then went ahead, once I had what I thought were good backups & again did the:- move user folders, by Kari & in doing so, made a horrible error, I inadvertently mixed up my dive assignments & long story short, kept rebooting & restarting in audit mode.
I then recovered my middle of 3 full backups of the entire system & recovered it back to my SSD,
From the start of the new recovery installation, upon boot up & just before bios, I sometimes got a red flash or red flicker prior to loading bios, this has now improved since I removed all extra devices, I am NOW currently down to bare bones devices, ie:- 1 stick of ram, SSD, keyboard & mouse, both being on USB IO panel, all USB connections on MB disconnected.
I was before going to “bare bones” always stuck in constant restart when rebooting & if I disable fast start up in power options, sometimes I was stuck in shutdown.
If I leave fast start up in power options, it will usually shutdown OK
If I leave the system running with no input for say 20 minutes, the system will sort of lock up, being the start button will go black & not allow to access shutdown, restart etc in classic shell.
If I try to windows update, it will indefinitely lock on searching for updates until that screen locks still as it were, searching & there in no activity & the green action bar freezes, I can however shutdown that window with no ill effects.
I have done WD data lifeguard test on SSD in extended test & all is passed OK.
This system ran fine for approx. 2 weeks, but started to have issues firstly on installing a 775mb windows update, the system wouldn't install it, would try but then rebooted saying removing changes?
Having read everything, wherever I can find it, & found nothing EXACTLY the same, BUT while re reading the motherboard manual, I see that my memory is not from a "qualified vendor"????
My memory is:-
Could this memory be my problem?
To me, this seems hardware related, & probably memory because of the issues?
Now after all this & system now being at a bare bones system stage & after many restarts & shutdowns, everything has improved dramatically to the point where I have no restarting & shutdown issues at all.
I know you’re going to tell me to install one piece at a time until all hardware is back in & no problems, but what & where should I be on the lookout for & in what order of re-installation would be the best way to troubleshoot this?
Any help would be greatly appreciated
Thanking you all for any help you can send my way
Much appreciated
Peter
KINGSTONS
AMD FX9590
Crucial 512GB SSD
WD SATA drives
Microsoft office
QuickBooks
Problem being:-
My memory is:-
Much appreciated
Peter
- Windows 8.1 Pro
