Problem installing from WES 8 CTP 32-bit bootable IBW
    Hello all,
    Not sure whether or not anyone in this forum can comment on Windows Embedded Standard 8 (WES 8), but just for grins I'll post. I'm trying to install from DVD onto my hardware platform using the 32-bit bootable IBW, but it always fails as follows. The black screen with the blue beta fish comes up, then the next thing I expect to see is the little animation with the tiny balls chasing one another in a tight circle (sorry, best description I could come up with) vertically below the fish. I never see the animation, instead the system just reboots. Can anyone help me with this or point me to some other place where I can get some help? Thanks.
    Portsmouth Hants
    TheWES 8 IBW is buggy - even if deploying a configuration file - it cannot match all the dependencies, calculate the OS footprint size, and takes forever. If you only have 30 days to evaluate the system you've created - it is not worth the time spent. Wait till they release something more competent - or move the modules to the WES 7 distribution share and try to build the setup you want that way - WES 7 at least worked properly. (I haven't a clue if this would succeed!!)
Problem installing Win 8 on new PC from USB
I bought the Windows 8.1 student edition to install on a new PC. I used Microsoft's media creation tool to get Windows onto a USB for the PC to boot from. I've tried selecting all the editions (N, Pro N, etc.) when doing the media creation tool, and I've selected the 64 bit, but each time I input...
Installation & Setup
Problem Installing Quicktime 7
I need to install quicktime 7 for my airsight IP Cameras. Problem I am having is that the installation just keeps on trying to install it. I wait and wait, nothing happens. Then I try to uninstall, can't because it is still installing. I Turn off the computer, then tried to install quicktime 7...
Build bootable EFI USB from bootable third party ISO
I read the tutorial on building a Windows EFI USB stick from the Windows ISO. I want to build an EFI/USB from an ISO of a bootable third party application, which is not designed to boot from UEFI. First, I went through the steps in Diskpart. Then, I copied the files from the third party ISO to...
Problem creating Bootable USB for Lenovo UEFI Diagnostics
Hi all. My Lenovo Twist (Ultrabook s230u) has ran into problems - and tries to run AutoRepair but gets hung up each time. Lenovo has instructions for creating a bootable USB to run UEFI diagnostics: Lenovo UEFI Diagnostics - Bootable USB (Create it on Windows OS) - Desktops / Notebooks /...
Trying to install win8 from a bootable usb device- Problem
Hello, I'm trying to install wi8 from a bootable usb device, i've this screen for more than 30 minutes now ..any help ? 25822 it's NTFS formatted.. i set the BIOS as the following: 1st boot dev. USB-ZIP, 2nd USB-HDD, 3rd USB-CDROM i made it via Windows7-USB-DVD-tool
Problem installing
Hi- I tried to install Windows 8 on to a new partition on my PC several times, It appears to install correctly but after it has installed and restarted, and gone through the registry setup files etc the screen just goes black and nothing happens. I've tried 'refreshing the PC' - this doesn't...
Problem during installing updates
Hello frnds, When i check for windows update it shows 3 updates and one optional update is ready, but when i install them it always shows 0 byte and 0% completed. so how much time it take to install?
Windows Updates & Activation
