Solved Clean Installation Problem
krelian0531
I am trying to do a clean reinstallation of Windows 8 on my Alienware X51 and am having a problem. After I boot to dvd and after the install starts there is a screen that reads "getting Devices Ready" and then the monitor goes black. After a while the computer will try and restart itself only to have the screen go black again. I have some experience in the past installing previous versions of Windows but never had a problem like this. Any help would be appreciated.
    Alienware X51
    Intel I7
    GeForce 640 GT
Installing this version of Windows is a little different.
When it says it is getting devices ready you will get a black screen when it gets your video ready and may black screen a bit later.
Just be patient and give it a bit of time and it should continue installing.
    Windows 10 Pro 64bit
    Home Custom Build
    Intel i7-4770K
    Asus Z87 Sabertooth
    16 Gig DDR3-2400
    Gigabyte GT740
    Onboard
    Benq 27" - Benq 22" - Dell 23"
    1680x1050
    Samsung 840 pro 128g SSD
    1xWestern Digital Caviar Green 1TB
    2xWestern Digital Caviar Green 2TB
    Seasonic 760 watt platinum
    HAF-X
    Noctua NH-C12P CPU Cooler
    Logitech illuminated keyboard
    Logitech Performance MX
    Cable
    Avast Internet Security
After several restarts I get a blue Recovery screen that says "PC could not be restarted" and then the computer shuts itself down. Any idea as to what that means?
    Alienware X51
    Intel I7
    GeForce 640 GT
welcome to EightForums.
Is this a Dell Pre-install Windows 8 PC?
If yes.
Boot the Windows 8 x64 DVD in UEFI mode.
    ME, XP,Vista,Win7,Win8,Win8.1
    Notebooks x 3
    Desktops x 5
    Towers x 4
That did it. Thank a lot for your help.
    Alienware X51
    Intel I7
    GeForce 640 GT
You are welcome. :dinesh: :dinesh:
    Notebooks x 3
    Desktops x 5
    Towers x 4
