Problem,removal disc shown when no drive conected
  1. #11
    Quote Originally Posted by znod View Post
    Got it. We were posting at the same time. Did you try the possibly simple fixes I mentioned above. Probably too simple to work.
    don't know what I did followed u or not? I opened my computer and right clicked the removable drive and eject clicked and then inserted the pen drive which showed another disk I drive and did the eject in the same way \. and closed the window and restarted the pc but the same thing it the same what u said?
  2. #12
    Close enough.
  3. #13
    znod...........but still the same ..I have just clean re install the windows 8 but the problem is same,,,,,,,,,,,
  4. #14
    to the experts and mvp.....please suggest me is the fault of pc? what if I leave that drive as it is ? does it harm my pc anyway/? I am terribly getting tension from this problem......what if I go to disk management and hide the drive?please help me
  5. #15
    ME, XP,Vista,Win7,Win8,Win8.1
  6. #16
    Try right-clicking that Removable Drive and look at the Properties/Hardware Tab to see if it gives you any additional insight. You could also try Control Panel > Autoplay and set everything back to defaults.
  7. #17
    Here's a good article that might shed some more insight on your issue:
    What are these "no media", "removable" drives on my system?
  8. #18
    Hello again quickslvr,
    As stated previously, that removable media appearance in your computer folder is probably some necessary hardware that was detected during installation (like a card reader, etc) and, if you have read the above article, it could even be some weird "out of the ordinary" hardware like a USB hub on you monitor. Moreover, after reading that article thoroughly, I am in agreement with the author; in that, if you can't find it, don't do anything drastic to try and make it go away, because it is (more than likely) necessary hardware for your configuration (even though you don't know what it is yet). Now, I am basing my assumptions on the fact that you just did a clean install so that eliminates (in my mind) any user errors that could have been introduced over time.
    However, I do have one more place for you to look and I apologize if this has already been suggested:
    Quote Originally Posted by quickslvr View Post
Page 2 of 2 FirstFirst 12
PC keeps chicking disc drive every 10 seconds or so.
I don't know why all of a sudden it is doing this, but the disc icon shows up near my mouse and my PC makes a noise every 10 seconds or so as if there were a disc in my disc drive, where there is actually not one. This happened after I uninstalled and reinstalled a graphics driver. I uninstalled...
Dynamic Disc vs Pooling software-Drive Bender, Drive Pool
Hello everyone, I have a computer that acts as a home media server with 8 storage drives in it (ranging from 1-4TB). I have windows 8 x64 Pro installed. I wanted to simplify my system and use Dynamic Disc to span across several drives as I now use Drive Pool to do this. In drive pool, if a...
Installation & Setup
100% disc usage on secondary drive
I have a secomdary drive with all of my games and it is at 100% usage even though read and write speeds are at 0 each. I will put a few pictures in here. Gyazo - f49422631f1d8dfa0f8ce8a8221e79ec.png and Gyazo - 26d80cde419df07ccadf33cccbe5d985.png
Drive letter assigned to external USB disc changes random
My USB disc comes up with the letter 'J'. Because I have references to it with a letter 'X'. I want to change it and I do that in the Computer Management tool with the Disk Management utility. Computer - Right click - Computer Management Disk Manegement - Right-click the drive and then click...
Drivers & Hardware
Safe removal of USB drive without loss to data
How do I safely remove my USB drive in Windows 8 without losing data.
Drivers & Hardware
Disc problem
When i try to download something with IDM or utorrent download starts then i get Write to disc error that i'm not allowed/authorized to write to disc... Can someone help me solve this? TNX
Drivers & Hardware
Canon MF4150 conected to USB will not pring
My Canon MF4150 is directly connected to Win 8 machine via USB. I was able to install printer using windows 7 driver. Win 8 can do scanning but is not able to print. I've tried to uninstall and install, change usb port from 1 to 2, nothing seems to be working. Printer connection seems to be good...
Drivers & Hardware
