How to fix multi monitor, mouse lag/low fps issues?
    Using an amd r9 290 card and intel hd 4600, in multi monitor mode, which means one monitor connected to the amd card and the other to the intel onboard, The problem is that basically there is mouse lag and fps issues when playing videos on the second monitor which is the one connected to the intel card, if I disable the intel card display adapter all those issues, the mouse lag and low fps are gone, so multimonitor is 100% the issue and I don't know why it is happening. Maybe the onboard gpu has some problems? Because it happens even if I use the onboard card as primary display adapter disabling the r9 290 display adapter.
    United States
    Windows 8.1 Pro 64-bit
    Intel + AMD combinations are known for being problematic. Do you have the latest graphics drivers from the motherboard and/or PC manufacturer's site?
Multi monitor GUI screen tearing.
hey all... i have 6 displays hooked up to my 2 gtx 770 4gb cards... yeah i know. 6.... anyway i know that with nvidia screen tear is common on multi displays... they arent even serious but im very perceptive of it and i want to know if you all notice the slightest bit with your multi...
Graphic Cards
BSOD dpc_watchdog_violation MULTI-MONITOR
Hello everyone, First, I'd like to apologize for my bad english. My computer crashes when I start a fullscreen window (especially games) on my main monitor (I'm using multimonitors). When I unplug my second monitor, everything works properly. I've got a BSOD and DPC_Watchdog_Violation shows...
BSOD Crashes and Debugging
Multi monitor start screen
As you'll know, with multi monitors in Windows 8 you have a start screen on both monitors - but when you launch an application, it'll launch on the screen it was previously on rather than the screen you launched it from (the screen you were using the start menu on). What I was wondering is if...
Multi monitor annoyance/issue
Bit of an issue with 2 monitors: Monitor 1 is on start screen, monitor 2 is on desktop. Open an app on Monitor 1 like Store for example and browse around, hit Windows key to go back to start screen. When I click on monitor 2 to do something in an open application, monitor 1 flips back into the...
Multi monitor setup
Greetings, I was anticipating this to be a headache, since it only worked in Win7 by throwing spaghetti at a wall. Essentially, I have a dual monitor display. The right monitor is primary, the left is to be used by art programs, movies, games, and other more specialized work (as well as...
Multi-monitor, how to choose which screen shows Metro?
My "primary monitor" is set to the smaller of the two so the Metro start menu shows up on it. Occasionally, though, it'll show up on the secondary screen. Does anyone know how to control this? Sometimes I watch Netflix on the smaller one and would rather have Metro show up on the secondary...
Performance & Maintenance
