I need help setting up a second monitor
    System Manufacturer - Acer
    System Model - Aspire E1-571
    Processor - Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz, 2501 Mhz, 2 Core(s), 4 Logical Processor(s)
    Installed Physical Memory (RAM) - 4.00 GB
    As the title says I would like some help setting up my TV as a second monitor. I own this( cable to go from my laptops HDMI port and this( to go from the DVI to the VGA on my TV. My computer doesn't respond at all when I plug in the HDMI cable but the screen turns black for a second when I tell it to project to a second screen. I don't think it's an issue with the TV as it is regularly used as a second screen for a 2007 issue Macbook and 2012 issue Macbook Pro.
    I can provide more specs if you need, thanks.
    Sydney, Nova Scotia, Canada
    Windows 10 Education 64 Bit
    DVI-I is digital and analog so you can use a DVI to VGA adapter to pick off the analog signal and feed it to a VGA connector. I don't think HDMI has any analog signal, its digital only. There is no analog signal for your DVI to VGA adapter to pick off. The DVI signal is a DVI-D, digital only, coming out of the end of your HDMI to DVI cable.
    All you need is an HDMI lead, or a VGA lead with Sub D plugs.
    Connect that lead up from your Laptop to your TVs HDMI input, or the VGA input.
    Preferably HDMI (v1.4 spec), it is digital only. you can buy such leads in DIY and pound shops etc.
    You have not said what inputs the TV has. Usually that will be HDMI if it's reasonably recent.
    To set that up just right click on Desktop > Graphics Properties > Display > Multiple Displays.
    Or go to the Charms bar > Devices > Project > Second Screen > Select what you require, Duplicate, Extend etc.
    Obviously the TV will have to be set up to select the relevant HDMI input though it should detect the input automatically.
    Old thread guys, Jul 2013. I think the OP has moved on. Not your fault Helmut, it appears the other noob is just spamming threads with links to his web site.
    Quote Originally Posted by alphanumeric View Post
    Nick may hold something of a clue about OP. "Karp, Karping" is term we used for "troll, trolling" on CB radio way before internet.
    PS. It would be nice if threads not accessed few month be marked "Read only".
What should this setting be on Device installation Setting
So i was looking around and i noticed my device Installation setting is not set on recommended but only set on No let me choose what to do and then Always install the best driver software from windows update, and then set on automatically get the device app and info by your device manufacture here...
Installation & Setup
'Wireless' setting doesn't appear in the Change PC Setting
I've got a Lenovo all-in-one 64 bit PC. When I click on Change PC Settings in the Settings charm the 'Wireless' option is missing. It appears exactly as expected on my laptop - also a 64bit windows 8 machine. Anyone any idea what's going on? (My bluetooth mouse and keyboard are working as is...
Network & Sharing
Setting/Re-Setting Windows 8 Native Mail Client/Tile
My parents bought a PC last year running W8. I set up there talktalk E mail accounts in the W8 Native E mail client from the Mail tile at the start screen without any problem. All worked fine until recently when in order to download an app they had to register an Outlook E Mail address. Not sure...
Browsers & Mail
Setting monitor to shut off display. Not coming back on.
So I have had this annoying problem for awhile and finally going to ask about it. Not sure which forum this belonged in sorry. At first I thought this was a sleep issue...but it doesnt seem to be. My PC is set to shut off the display...then some time later go to sleep as well. Well for some...
- Help - Extended monitor and laptop monitor not working
Hi, Today I plugged an hdmi to vga cable into my Win 8 sony vaio, and I plugged the other VGA side of the cable into an acee 22" monitor. I then chose from the right hand windows 8 panel to "extend to monitor", the laptop screen went black, the monitor screen remained without signal (extended...
New to Windows. Setting up 2nd Monitor
Hello Windows world I have my first Windows laptop after using Mac for 20 years and so far so good. I am running Windows 8 on a Samsung 350V5C laptop 6GB RAM. I'm struggling connecting to a second monitor, the problem being my laptop connects OK VGA to VGA but doesn't stay connected. After...
Graphic Cards
Dual Monitor - Secondary Monitor Flashing Issues
I recently purchased another monitor so I can run dual-monitors on my newly upgraded-to Windows 8 desktop. I set the monitor up last night, and I haven't had any major issues so far... One issue that I've run into, though, is the secondary monitor (regardless whether it's the monitor I owned first...
Graphic Cards
