Secondary monitor flickering problem
    Windows 8 x64
    HiLast night my laptop (running Windows 8 x64 with a secondary monitor) was working fine. I put it to sleep and when it woke up this morning the secondary monitor is flickering a lot like this:
    I have tried uninstalling the AMD driver and restarting then installing the latest version but it still doesn't work. The screen even flickered when the AMD driver was not present. I connected the monitor to another laptop and it worked fine.I played about with the refresh rate in the catalyst control center and it ended up making the laptop screen flicker instead so I reverted the settings back.Anyone know why this would have just started happening and how to fix it?
    Maryland USA
    is this a movie you are trying to watch or is this your desktop background?
    Windows 8.1 Professional 64-bit
    You can capture a screenshot by clicking "Print Screen" on your keyboard, then pasting it into Paint and saving it.
Second monitor flickering on boot/awakening
Hi I have a duel monitor set and a while after I updated to Windows 8.1, it started to flicker for no reason. It is only my second monitor. It flickers whenever the screen has been black for a while. Like when I start the computer or wake it up from sleep mode. I am currently using a HP computer...
How to make taskbar only appear in secondary monitor ?
Hi Folks, I have a dual monitor setup at home, my current setup is that I made my 'side' monitor as primary monitor in windows setting. I am doing that to be able to make all newly created icons that is bound to desktop automatically go into my 'side' monitor. My 'side' monitor is being used...
Windows 8 Mail on secondary monitor
How can i set the Windows 8 Mail application to start up on my secondary screen? I've installed 'Actual Monitors' for this purpose, but because i can't find an actual path to the application 'Actual Moniters' can't handle to open the Mail app on the second monitor. Does anyone know to get...
Browsers & Mail
Touch gestures on the secondary monitor...
Just a quick question. I just set up my Windows 8.1 system with a touch sensitive display in a dual monitor configuration. The touch functions worked right out of the box however if I don't set the touch monitor to be the primary display, all my touch gestures get sent over to the non-touch...
Drivers & Hardware
New install: Nvidia GeForce 560 ti; Monitor flickering!!!
Hi everybody! I recently bought a new, 600w power supply and Nvidia GeForce 560 ti. We couldn't install it ourselves as my case was too small and fiddly, so we took it down to a computer shop who did it for us. Now suddenly my monitor starts flashing and cloning frames in animations. Here's a...
Graphic Cards
Flickering on external monitor
Hi all, I am currently experiencing flickering on my external monitor, connected via VGA from my laptop--flickering like a low refresh rate even though it is at 60 Hz. I have a Sony Vaio, model vpcsa490x. The laptop has switchable graphics cards and when I switch into the Intel 3000, there is no...
Graphic Cards
Dual Monitor - Secondary Monitor Flashing Issues
I recently purchased another monitor so I can run dual-monitors on my newly upgraded-to Windows 8 desktop. I set the monitor up last night, and I haven't had any major issues so far... One issue that I've run into, though, is the secondary monitor (regardless whether it's the monitor I owned first...
Graphic Cards
