Undefined Problem :( / No Signal Input
ankur850
Gwalior
Hello ! :D
First of all my System Details :
  • Processor : Intel Dual Core E5200 @2.50 GHz
  • MotherBoard : Mercury PIG31T
  • RAM : 2 GB DDR2/ 667 Mhz
  • GPU : Gigabyte AMD HD 6670 2 GB DDR3
  • OS : Windows 8 Pro 64 bit
  • PCI-E : x16 2.0
  • PSU : ATX 450 Watts
I use my PC daily and never i got the problem like this, My PC is 4 years old and i upgraded it with HD 6670 Card 6 Months ago.
Problem
Last night everything was going fine with my computer and today in morning i Started my PC as usual, I listening music, checking fb as usual,but after 15-20 min while using my Computer, Monitors says ' No Signal Input '. But i still hear the song !! , so when i tried to low the volume, keyboard keys doesn't work, no mute, no capslock, numlock probably it is halted with GPU. So Keyboard and GPU Halted at this stage. So i unplugged the power cable. I Plug it and start it again and i saw 'No signal input' then i tried to plug the VGA to onboard Graphics and it works but my Graphic Card fan is spinning but i didn't get the Signal from GPU. After some time I Shut my pc, Unlugged Replugged and start it again. Now this time Onboard VGA not working and saying 'NO Signal Input' on Monitor. I remove the cable from onboard vga and plug it to Graphic Card VGA and it works but after15 -20 min it saying "No Signal Input". And one more thing, i write this post using onboard GPU and i didn't fell any problem using onbard VGA.
So probably the simple word for this is : Sometimes Onboard works and Some times GPU Works. But the onboard is working great but GPU giving No Signal after 15-20 min.
What i Tried
  • Reinsert RAM
  • Clean GPU/ Reinsert it in PCI-E Slot
  • Clean PSU
  • Reset Bios by Removing Battery from Mobo..
Any help greatly Appreciated. Thanks Windows 8 forum for discussing this thing here
    Windows 8.1, Windows 7, Ubuntu/Linux 13.10
    Mercury PIG31T
    Intel Pentium Dual Core E5200 @ 2.50 Ghz
    Mercury
    2 GB /667 Mhz , Diginet
    AMD Radeon HD 6670 2 GB DDR3
    Realtek HD Audio
    HCL
    1366x768
    Western Digital Cavier Blue 320 GB
    Frontech ATX 450
    Frontech
    Stock
    Logitech Internet Pro Desktop Black
    1 MB /25 GB Month
    Chrome, Internet Explorer, Chromium
    Tech Speak
Are you using a DVI or VGA cable?
The problem could be your monitor or your cable.
If you have the other type of cable try it.
If not, does your TV have VGA or DVI input? Connect your PC to your TV and see if that works, if it does then it could be your monitor.
Do you notice if the monitor is switching from digital to analog by itself? It should display it when it does.
Before this problem did you recently disconnect your video cable and the problem only start after you reconnected it?
Check the pins on your cable for bent ones..
Brooklyn
    HP G60
    3 GB
    Nvidia GeForce 8200M G
    1366 x 768
    Chrome and Chromium
    Avast Free & Malwarebytes
I use VGA Cable, and onboard display works like charm so there is no problem with Monitor.
I think it is PSU or GPU fault. Wha's your opinion now . I m still worrying.
    Mercury PIG31T
    Mercury
    Realtek HD Audio
    HCL
    1366x768
    Frontech ATX 450
    Frontech
    Stock
    1 MB /25 GB Month
    Tech Speak
Sure, heres the quick check for a bad driver..
Start the computer in SAFEMODE WITH NETWORKING
Use your computer as normal, you may have to change the resolution, the icons may be too big for you to handle, lol..
If the monitor stays working, then uninstall your video drivers, reboot in normal mode...
If all stays working then DOWNLOAD the drivers for your graphics card, do not use the driver cd..
And let us know the results..
Brooklyn
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
not works, same happening.
Keyboard doesn't work after display gone, and CPU still running.
    Mercury PIG31T
    Mercury
    Realtek HD Audio
    HCL
    1366x768
    Frontech ATX 450
    Frontech
    Stock
    1 MB /25 GB Month
    Tech Speak
