JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Solved how to enable small icons in taskbar menu using registry tweak ?
Hi all.
I have a simple question how to reduce the taskbar menu icons using regedit
For now they are big to me.
Of course I know how to reduce the taskbar menu icons but I want to reduce them using registry.
Is there any trick to do this?
Maybe someone you know and you can help?
here is where i want to change it to smaller icons on taskbar meniu.
And this is the way i know how to change but not do not know how to do that with registry.
Thank you in advance.
Hello Polas, and welcome to Eight Forums.
The way you are showing is how to change the size of the icons on your desktop, but not on the taskbar.
OPTION TWO or THREE in the tutorial below can show you how to change the taskbar icons to be large or small using the registry. It's the same in Windows 8.
Taskbar - Use Small or Large Icons - Windows 7 Forums
Hope this helps,
OS
Yap it works now.
I found how to change taskbar meniu small icons buttons.
Thank you
37.4 KB
You're most welcome.
OS
