Release Preview - Nothing but problem after problem after problem.
  1. #11
    That sounds weird....I've never heard of issues like that due to a card reader....but yeah, hopefully that gets fixed before RTM. That is unacceptable.
    Speaking of such, I remember once installing Windows 7 on a laptop and we were trying to get an SD card to be read and I saw that the driver was never installed. I thought it was odd that Windows didn't have a driver to install for that to get it to work. So I had to find HP's driver for that and it was working. Strange stuff I say.
  2. #12
    Tropical Island Pair a Dice
    I did a Clean install, formatted the CP partition in the setup section, installed in 15 minutes and no problems.
    ISO installed on a flash drive.
  3. #13
    Hafnarfjörður IS
    Hi there
    I had a TERRIBLE time but eventually got it OK
    Something had set my internal "C" disk so the system thought it was a USB stick which caused no end of problems after install.
    Totally wiped the Disc -- actually changed the disk to SSD -- went fine -- less than 12 mins from start install to Bootup.
  4. #14
    Windows 8 Pro/Windows 8 Pro/Windows 7 64 Bit64Bit/Windows XP
    Quote Originally Posted by BillWindows View Post
    Quote Originally Posted by HPDeskjet View Post
    I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market.
    1. Doing a clean install did not install a clean installation of Windows 8. It took three attempts. Previous wallpaper, user login avatars, etc. kept showing up in the new supposedly clean install, even when installing with a local account.
    2. At shut down I am constantly getting a winlog.exe error stating that I need to insert a disk in to various empty drives. This stops the computer from shutting down. The error message appears 18 times and has to be clicked away every time it appears. The OS shuts down but my computer hardware keeps running [fans, disks, etc.] I fear I may have to get rid of Windows 8 RP before it ruins my entire PC.
    3. After the OS has shut down the computer itself will not switch the power of. The computer light showing disk activity is constantly on, even though the OS has been shut down.
    I'm going to have to give up on this OS. This release candidate is not working at all well on my setup. Highly peculiar, especially as I had no issues with the Customer Preview and nothing has been changed in my PC hardware setup.
    I had exactly the same problem, clean install, dual boot with Windows 7, formatted the partition, had to install 3 times to get it to work, but was very quick when it did install.
    Same error message when closing down, keep hitting cancel, then closes down but wont turn off and have to manually turn it off.
    I must admit though it runs very well and slick when its going. I'm sure MS will fix this up shortly, I had a similar problem with the CP when I first installed it, about a week later it was fine, Rome wasnt built in a day.
    Do I sound like a Fanboy or what.
    Love the Tulips Deskjet, I'm originally from Holland but have been living in Australia for over 50 years. Went back to Holland 2 years ago, loved it, will be going back again soon.
    I ran my PC this morning downloaded a few Apps, there were a couple of updates, played around with the Apps for a while then closed down the machine, and now it closes down with no problems, so the updates must have fixed things, for me anyway.
Page 2 of 2 FirstFirst 12
Is it my DVD writer problem or software driver problem?
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
Drivers & Hardware
Problem with checking for problem solutions Windows 8.1 PR
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
Performance & Maintenance
Windows 8.1 Problem with application preview from taskbar
Hi, recently I installed latest Windows 8.1 update (Update 1/Spring update), and later latest Beta Nvidia driver. After that, an strange problem showed up, which is annoying and hard to explain (especially with my poor English :p). I recorded a video which represents it (look at the thumbnail...
Context menu item problem and accessing files problem
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
Problem deleting a file, REAL problem
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Shut down problem + Sleeping problem
Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K Problem 1: When i shot down my pc via windows Shot Down button pc doesn't go Off. I see Windows Off screen, screen goes black but pc still running. Solution? Problem 2: When my pc goes sleep or monitor goes sleep i can't...
ok big problem installing Windows 8 Consumer Preview in virutal box
ok big problem, i installed the virutal box just like in your tutorial I downloaded the windows 8 iso from the site you gave I picked the 32bit one because that is what i have I also used the wizard one that microsoft gives you so you can burn it to a dvd So I followed all the directions and...
