problems with freezing, and not refreshing. Please help
    Windows 8.1 x64
    So I've been having trouble with my laptop. I downloaded advanced warfare and after a few hours it froze on me. I waited 5 minutes and I powered it off by the power button. A hard shut off. I opened advance warfare up again and it froze again. I hard power off again. I tried again but then I ran sfc scannow. I said it found corrupt files but couldn't fix them. I then ran AW again. It froze again. but this time I got mad and slammed my fist down on it. I realized where I hit was on top of the HDD and once I did my computer restarted which showed I hit the HDD. Well I booted it up and I got the blue screen error starting up called unmountable boot volume. I looked at my bios and it said my HDD is there so it's not disconnected. Luckily it did a automatic repair and it fixed it to where it booted up. But now I get major freezes from opening some stuff. It happened randomly and it'll freeze for 5 minutes. I used CCleaner, Sfc scannow, I scanned my computer with AVG, I checked my drive for errors, and I restarted my computer because I hoped it might fix. It did not. So the last thing I needed to try is refresh my computer. I did, it got to 77% then it started up my regular booting screen. I refreshed it over an hour ago. Wtf is going on, I know I cojldnt have damaged my HDD. Please help.
    win8.1.1 enterprise
    just guessing of course,but seeing how it got worse after you hit it then its likely you did damage the HDD, good luck
BSOD/Freezing Problems
Hey there, I'm not sure if this is the right section to post this in, but I'm in need of a little advice. Recently, my laptop's (Some sort of a Compaq) hard drive was dying, I was going to get it replaced but was told there's really no point; There's every chance something else would go soon if...
BSOD Crashes and Debugging
Refreshing PC
I recently refreshed my PC and when it was finished it took my adobe flash player out. When I go into recently removed apps its in there but no option to reinstall. when I go to adobe sight it says that my PC is already installed and wont let me reinstall it. HELP!!
Refreshing PC via USB
Hi guys, I was a part of seven forums for awhile. I'm trying to troubleshoot my PC. Hopefully I'll figure this out soon. I mean hell I'm A+ certified I feel ashamed even asking for help but.. Lately I've been having a lot of issues with corrupted files, and things not working in 8. IE, I...
When I installed Windows 8 on the day it was released, I had to do a refresh because the apps in Store were not working right. As I remember there were others having the same problem. Today I ordered a laptop for our granddaughter which will, of course, have Windows 8 on it. Does anyone know if...
Resetting, refreshing and installation problems
Hello everyone. Yesterday I chose to take my $15 upgrade to windows 8 because I bought a Lenovo laptop on June 10th. I got an email saying to download the windows upgrade assistant, so I did. However, it completely downloaded Windows 8 a day early. I checked the properties by right clicking my...
Installation & Setup
Suggestions for Freezing Problems (culled from other posts)
This is just a list of the most recent freeze fixes compiled in this forum: As it seems a bit confusing, I've highlighted the specific instances in RED Feel free to add to this topic or to bump it back up to the top. FYI - AVG (and other antivirus') have been implicated in freezes, even...
