Problem:Multiple taskbar on same screen using dual screens
    Some weeks ago, I noticed an odd problem with my taskbar.
    While using my laptop at home, I use an exterior monitor to extend my desktop, and usually set the monitor as my primary. Occasionally, I would notice that my open apps would appear to be greyed-out (and therefore un-clickable) on my secondary screen. All the pinned apps would be full colour, but would only respond to clicking as if I was starting a new version of the app (e.g. a new browser window rather than switching to the existing one).
    It appears as though a second "ghost" taskbar was over top the main one, and only on one screen. This ghost taskbar would block any attempt to click on the taskbar underneath. Unlocking the taskbar and moving it, for example, to the side, would confirm this as the ghost taskbar would drag and snap to the edge, leaving the normal taskbar at the bottom of the (same) screen.
    The ghost taskbar would disappear (or perhaps merely move behind the main taskbar) if the taskbar is swapped with the primary screen (causing the tray to move over).
    A reload of Windows Explorer via Task Manager seems to be a temporary fix, as is restarting the computer. However, this issue may appear multiple times per session, and within a short time of any reload/restart. This also does not seem to occur when using only the laptop screen.
    I do not run any desktop customization software, and have triple-checked for any Windows, Microsoft, or driver updates. I am moderately competent in doing repairs to the computer so long as I have reasonably detailed instructions on how to do the fix.
    I have scoured the internet and have come across nothing that describes my particular issue. Your help would be greatly appreciated.
    Screenshots of the phenominon are available if more clarification is required.
    Windows 8.1 x64
    Same problem
    Quote Originally Posted by Prosk View Post
    I have the same exact problem which started yesterday, I could find nothing regarding this online (except this thread). Once I try to extend screen using a second monitor an additional taskbar appears on the same screen. Each time I disable and enable the screen I get an extra taskbar on that same screen (to infinity?!). The only workaround seems either a pc restart or an explorer.exe "restart".
    Your 'ghost' taskbar may just be a taskbar that is expanded to two rows. When you have the option 'show taskbars on all displays' (see below) enabled, not only does it show up on the second screen, but it can be expanded/collapsed separately from the first one.
    Right-click on any taskbar and make sure it is unlocked. Go to your second screen taskbar that is double-high. Hover over the top edge and drag in down to one row.
    Relock your taskbars if you want to.
    Hopefully it will stay one-line after a reboot.
    Central IL
    Linux Mint 17.2
    If you do not have a third party utility like Classic Shell or Start8. Yes there are two toolbars. One is the Desktop toolbar. The other is the Metro toolbar. This behavior happened with the 8.1 update.
Both my screens are the same model and this is a problem
I'm running Win 8.1 64 bit. Both of my screens are the same model from the same company. I have an Asus motherboard and an Asus graphics card. The one screen is hooked up to the graphics card with HDMI and the other with a mini displayport cable. When I try to use the Cleartype tuner or a...
Graphic Cards
In dual screen mode, screens wont go to sleep
Hi, Sorry for poor english, I speak french. I'm runnig windows 8 on my Sony labtop. The labtop is located in the kitchen. I connect the TV in the living room in ''dual screen mode'' to the labtop. When i'm listing to music on the labtop (windows media player), the 2 screens won't go to sleep...
dual monitor displaying taskbar off screen (not autohide)
Hi people, I've recently got a new laptop with windows 8. I bought a HDMI cable to connect it to my TV.... I can get the display to show 2 different desktop (which is what i want!):D BUT.... the laptop screen displays what i assume is the incorrect resolutions or something.... because...
Dual Screen Problem, Mouse not moving over.
Hello I'm using windows 8.1, 2 Screens detected and using the feature extend, however when I slide my mouse to the right it will not move to the next screen like it did on Windows 7, instead it opens the menu (the Windows+C menu).
HELP PLEASE - Multiple Users and Multiple Screens Question
Hey guys thanks for reading this post. For work, I run software that can only be opened a single time on a computer - no way around it - however, on my Windows 8 computer, I figured out that I can open the software on different user accounts on the same computer, and the software runs perfectly...
Taskbar all screens with open window
Hello all, I have two screens and my current settings are: I got my taskbar on both screens with the opened windows in it's own taskbar. This is good, but I just miss one thing: I can't attach a program/shortcut to the taskbar that is not my main screen/taskbar. This is very frustrating. ...
Dual Screen problem
Im using 2 monitors and when i go fullscreen on youtube for example it opens up a tiny video on the other screen. It has only just happened. Im using chrome btw but it also happens on I.E.. Thanks for any help.
