Solved System hangs on CHKDSK, used System REFRESH. Help?
Silverhand92
Home IT Guy
Alright, so I have my girlfriend's Win 8 HP done with a REFRESH, but it says it saves the documents, settings, etc. If this is the case, I need to find my files, if not, I have a much bigger problem with all of the files being lost, because that is the very thing I have been trying to prevent.
I have set up this post to auto-email me with a reply, so you can probably tell from that statement how urgent this is.
My Computers
System One System Two
    Windows 8.1 Pro Media Center x64
    AMD Athlon II X4 640 (Propus)
    MSI MS-7388
    4 DDR2 x2GB = 8GB Total
    AMD Radeon R7 250x Pro Series
    Motherboard Onboard
    Westinghouse Digital 22" LED TV
    465GB Western Digital WDC WD5000AAKB-00H8A0 ATA Device (ATA )
    698GB Seagate ST3750640NA PATA Device (ATA )
    931GB Western Digital WDCWD10EZEX-22MFCA0 (SATA )
    931GB Seagate ST31000528AS SCSI Disk Device (SATA )
    1397GB Seagate ST31500541AS SCSI Disk
    Corsair CX750 Bronze PSU
    Antec 200
    (3) Corsair CF 120 & (1) Corsair CF140mm fans
    Logitech Wireless SB 120 Media AIO Keyboard
    Logitech Wireless SB 120 Media AIO Mouse
    250 Mbps
    Opera
    System data courtesy of Speccy; Courtesy of Piriform Software.
  • PC2
    Dell Studio 1555-S
Usually it's under C:\Windows.old
EDIT: You should not have to do a refresh, chkdsk will take a long time to complete depending on how badly corrupted the HD is.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
As for locating files, it will depend upon where you stored them or programs you used stored them. Generally most programs will save, by default, in the Documents/My Documents Folder, pictures in their Folder, videos in their Folder. Opening File Explorer then clicking This PC in the left column will show those Folders in the right pane. If the files were saved into a different Folder you can Search for it by name.
    WinXP, WinVista, Win7, Win8.1, Win10, Linux Mint 20
    2 Customs and 12 OEM/Brands
    AMD and Intel
When I ran CHKDSK, it would hang at 11% for more than a couple hours. Unfortunately, at this point, I was forced to terminate power to the machine and attempt another option to get it to work properly. I tried Startup Repair, and all of the many other options provided with Win 8.1 allows you to attempt to repair it, resorting to "Refresh PC without losing your files" as the last possible option. I was able to get all of the steps completed, but when I logged into my girlfriend's account, the only things it appears to have kept are the desktop theme, lock screen, logon screen, and the Windows Store apps.... Everything else is not where it should be.
My Computers
    MSI MS-7388
    Motherboard Onboard
    Antec 200
    250 Mbps
    Opera
  • PC2
    Dell Studio 1555-S
When running chkdsk and it hangs at 11% for more than couple of hours is normal, I've seen cases it would take 24hours or more to fix the problem depending on how bad the HD is corrupted.
As said above, did you check if there's a folder called Windows.old under C drive, this is where your data is moved to when doing a refresh.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
I have looked in the Windows.old directory under the C drive. The directory with the username is there, but the sub-directories under that with the documents, pictures, downloads, videos.... Etc. ALL GONE.
My Computers
    MSI MS-7388
    Motherboard Onboard
    Antec 200
    250 Mbps
    Opera
  • PC2
    Dell Studio 1555-S
As said already, if the drive has a large chunk of bad sectors chkdsk can take quite awhile. Sadly, if those files were on bad sectors and you've run chkdsk even partially, they may be lost for good. I always backup important files before any kind of major repair like refresh or chkdsk.
The Documents folder under the username has nothing?
Edit: What does SMART report on the drive. SpeedFan or Speccy can tell you.
Edit2: There is recovery software like this one for Seagate drives: Restore Seagate Hard Disk Data having Bad Sectors ? Seagate HDD data Recovery Software
Also Recuva: https://www.piriform.com/recuva
The key is, don't do anything with the drive until you run the software and run it on another drive.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
