Need some help with a dimming problem
Cadman07
Ok I was using the consumer preview build 8250 for about 2 weeks with two monitors my main one being an actual lcd monitor connected by a DVI connector and the other being my TV connected with HDMI. and I noticed no dimming issues what so ever. recently I have added a second lcd to my computer and removed my TV from the mix I now use my hdmi cable in my ASUS monitor that I was using previously but now I am having issues with the screen "randomly" dimming I say randomly loosely because it does it at certain times Most of the time.. when looking thru the steam store once I scroll down thru a list about a fifth of the way the screen will dim and stay dim till I scroll back up same goes with web pages with videos also I noticed it happening While playing mass effect 3 multiplayer for you guys that have played the game, when I would look towards a enemy and the orange box would highlight the enemy my screen would dim and remain dim until I killed it or looked away... this is really becoming an severe annoyance and if anyone knows a remedy I would greatly appreciate it.. let me know if you need specs.. I have tried several different drivers with my video card and its still same results.. im hoping its just a setting I have over looked.
Oh and a quick add too.. this is only happening on my main monitor that is connected to my PC using the hdmi cable
Hi,
Type services.msc in the start page and press enter. Disable the Sensor Monitoring Service and stop it too. See how it goes.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Tried the Disable sensor montoring, It was already off the diming is also happening when windows popup anyone got any other ideas?
I had this problem on my Inspiron 1564, a BIOS update fixed it. Another thing that can fix it is locking the brightness of the screen in the BIOS (or turning the sensor OFF there). However I don't know if your BIOS support such things.
~Aeny
    Windows 8 CP x64
    Dell Inspiron 1564
    Intel i3 330M
    Dell (0)F4G6H Board
    2x4GB Corsair ValueRam
    Intel GMA HD
    Realtek HD
    Integrated laptop display
    1366x768
    1x Corsair Force III 128GB
    1x Western Digital Scorpio Blue 500GB (temp. out)
    1x Hitachi 5400RPM 120GB (temp. in)
    90Watt Dell adapter
    Dell Inspiron 1564
    stock
    Azerty stock
    Integrated Alps touchpad
Im using a desktop PC so i don't have any options like that.. ive also recent noticed that the windows that pop up and make my monitor dim if i move them away from the center the screen undims
Did you update your motherboard bios yet?
Did you run a Windows Update to see if it installs a monitor driver? If the monitor is generic in the device manager, look into visiting the monitor's hardware manufacturer to get a driver to install.
Did you check the monitor properties to be sure that it is running at a resolution and also frequency intended by the manufacturer?
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
I didn't mention this in the thread I had in the Crashes and... section, but while there was a problem brewing, as well as random freezes, the screen brightness fell, and became better when the problem was resolved.
    HP COMPAQ Presario CQ57
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
    Chrome Canary usually
    no Start menu modifications
