Need Major Help With Troubleshooting Sony VAIO Tap 20
    Windows 8 home premium
    Model SVJ2021, running 64 bit 8.0.
    When I start this, it immediately goes into Preparing Automatic Repair, followed by Diagnosing Your PC. Needless to say that is soon followed by Automatic Repair Couldn't Repair Your PC.
    I've been exasperated by computers in the past, but this might be stretching me to the point of no return.
    When I go into Troubleshoot after it tells me it can't fix it automatically, I tried a Restore. No Restore Points. Then I went to the command prompt, navigated to C:\Windows and did a Fixboot, Fixmbr and a Rebuildbcd. The first 2 completed, but the rebuild found 0 Windows installations. I went back into Troubleshooting and selected Refresh Your PC which keeps your files but fixes Windows problems. No go - There was a problem refreshing your PC. No changes were made.
    I got out a Windows 8 64 disk and looked for the optical drive. There is none.
    I got out an external CD reader, popped in the disk and went to plug it in to a USB port. Uh-uh. There is only 2 frickin USB ports on this monstrosity. One is used for the keyboard and the other for the mouse. Incredible. How can Sony have been making computers for umpteen years and design a Windows 8 machine with 2 ports?
    I have no USB hub, so I unplug the mouse, turn off the PC, plug in the external reader, hit the Assist button which allows you to get into the BIOS, boot from an external device, etc. I go into the BIOS, change the boot order, save the changes, go back to the Assist screen and hit the key to boot from an external device. I get a message - No Operating System Found.
    I'm pleading for some assistance from someone who has some knowledge of how this unit works (or doesn't work). My meager bag of tricks is about empty.
    I used another PC to clear some space on an external HDD, then used the Rescue Disk option off of Advanced Troubleshooting. Since I still only have the 2 USB ports I had to unplug the keyboard. It's now rescuing the Documents, Pictures and Favorites onto the external drive
    Windows 8.1 x64
    Since you can get into a command prompt, maybe you could look in the windows\system32\logfiles\srt folder and see if you can find the srttrails.txt file. If you do, copy it to a flash drive, or somewhere you can access and read or attach it.
    The text file might give us some indication of what could be wrong.
    Also, when you boot and look at the bios or boot device menu and see if a Windows Boot Manager is present and can be selected.
    Did you have any external drives plugged in either before or when the problem first occurred?
    You can get a wireless mouse/keyboard combo that only uses one USB port, if it becomes necessary.
    After the recovery finished everything was fine. I still have no idea why Sony would construct a computer without a CD drive and with only 2 USB ports. Are they that desperate to cut corners that they manufacture products that border on defective?
Sony Vaio keyboard errors
My friend's Sony Vaio laptop is giving keyboard errors - substituting the incorrect characters when typing. For example if I type the name "George" it comes out "Ge6rge". When I connected an external keyboard it worked fine. I know that there are ways to re-map keyboard keys. But if that...
Sony vaio VGX-TP20E
Hello, I have a Sony vaio VGX-TP20E. I put the win 8 disk into the computer and setup up the startup to boot from optical drive. But it skips it and starts up win 7 like it normally does. How can I install windows 8? The first time I did that win7 had some kind of virus in it so I went to the...
Installation & Setup
BSOD on Win 8.1 Sony Vaio
Hello, Random BSOD s started to show up on my laptop. The laptop came with win 7 and I installed win 8 to it afterwards. I have recently updated the OS to Win 8.1 and had 3-4 BSOD s in a day (driver_irql_not_less_or_equal netio.sys) Any help would be appreciated. Kind regards.
BSOD Crashes and Debugging
sony Vaio windows 8 a Sony Vaio windows 8....and noticed it has only C in case i qould like to format the laptop in the future,all data inserted would be eraSED,as it will format all Data there any way to open a new DATA D DISC?
Sony Vaio Pro 13 BSOD (I think)
Hi all, I have just recently got myself a Sony Vaio Pro 13 and I think I am having issues in regards to a BSOD. The symptoms seem to be related to power/standby but could be wrong. Yesterday, I shut the lid and went away. Got back from lunch and realised the fan was on full-speed while the...
clone HDD Sony Vaio Tap 20
I have a AIO Sony Vaio Tap 20 that I really like, but I want to run off of a different HDD that is a hybrid drive (SSD + HDD) to increase the responsiveness. I have cloned the drive using Macrium's Reflect, but the drive won't boot. At power up, it says "a required device isn't connected" and I...
Performance & Maintenance
SONY VAIO drivers
Can someone help me with finding Sony Vaio VGN-FW130E drivers for windows 8? My laptop model is not supported for win8 in sony's support...
Drivers & Hardware
