Solved Right click metro problems.
Yanaro
Problems with right clicking in Metro UI.
Hi,
Recently i got a problem that right clicking an app won't bring the menu bar (or whatever you might call it at the bottom of metro UI so now i don't know how to pin/unpin a program from start page
No bottom bar after rightclicking an app.
Any ideas how to solve this issue, thanks in advance.
    Windows 8.1 Pro x64
    i5-3470
    Corsair 8GB
Are you using a custom theme? Maybe it doesn't support Update 1 yet. Switch to default theme and check if it's solved.
    Windows 8 Pro - 64bit
Oh, thanks, that's indeed the problem, i didn't know that they turned the bottem bar into right-click menu.
    Windows 8.1 Pro x64
    i5-3470
    Corsair 8GB
