the module MSWINSCK.OCX not compatible problem
    hi every one ...I m facing the same problem too.((Run-time error '339': Component MSWINSCK.OCX or one of its dependencies not correctly registered: A file is missing or invalid.))
    ..I downloaded a MSWINSCK.OCX file. Then drag it into SysWOW64. Then gone to command prompt and run as administrator and typed in regsvr32 c:\windows\syswow64\MSWINSCK.OCX.
    even tried with
    downloading a MSWINSCK.OCX file. Then drag it into System32. Then gone to command prompt and run as administrator and typed in regsvr32 c:\windows\system32\MSWINSCK.OCX.
    but displays the same message
    The module
    "c:\windows\system32\MSWINSCK.OCX" may not be compatible with the version of windows that you are running.Check if the module is compatible with an x86(32-bit) or x64(64-bit) version of regsvr32.exe
    Windows 8.0 x64
    In the command prompt change directory to C:\Windows\SysWow64
    then run
    regsvr32 yadda yadda
    there are 2 different regsvr32.exe on the system.
    thank you for your reply sir but still got the problem
    Click image for larger version i did as u instructed but it says the module yadda failed to load seen in the image i have attached here.
    when i type regsvr32 on cmd the says-" to register a module u must provide a binary name..".... Click image for larger version
    I have the same problem here
    i have the same issue here and i have tried all ways to resolve it and till now didn't work
    any help...!!
0142.dll The specified module could not be found
Recently we started seeing this message upon startup of this Windows 8.1 computer: Run Dll There was a problem starting 0142.dll The specified module could not be found. When I research it online I cannot find that exact file name. There is a similarly named file related to HP printers,...
Having trouble finding Compatibility Support Module (CSM)
Hi, I'm having trouble finding CSM( legacy mode ) in BIOS, I'm using this BIOS version: American Megatrends Inc. X551MA.213. I'm running : Windows 8, 64-bit, ASUS notebook... I'm trying to change from UEFI to legacy mode in BIOS, and I need help because I can't find it on my BIOS. Thanks for...
igfxtray module stopped working
My brandnew notebook is a Dell XPS 15 (9530) with W 8.1. Suddenly I am getting this msg after login, with: c:\windows/Minidump\100914-6828-01.dmp c:\users\barend\AppData\local\temp\WER-47842656-0 sysdata.xml This seems very cryptic to me...the "explanation" (half a screenful) MS offers is...
A specified module Could not be found. After Custom Icons.
I recently installed a custom icon pack and now I'm getting this error when I right click on now my desktop and click Personatizlation but it gave me this error imgur: the simple image sharer any fix to his without a restore?
UEFI, turn of compatibility support module?
Could someone give me the heads up if it is still necessary to disable CMS in the bios to fully utilize a UEFI install? I'm getting conflicting messages from what I am reading, probably because I have no idea what I am doing. Cheers
Drivers & Hardware
antivirus compatible problem
i am new and my first post I have been recently using windows 8.1 but I am quite upset with this version of windows. because I have tried most of the top rated internet security for the installation but most of them are incompatible with win 8.1. so what is the matter despite of being upgraded and...
System Security
WLAN Extensibility Module has failed to start.
So I have bought a new wireless adapter as my old one had very poor strength and I am really impressed with the signal on this one but after a while it disconnects and then it says there are no available connections. I have to restart the adapter to get it to work again. If I am gaming online...
