the module MSWINSCK.OCX not compatible problem
shaggy517
hi every one ...I m facing the same problem too.((Run-time error '339': Component MSWINSCK.OCX or one of its dependencies not correctly registered: A file is missing or invalid.))
..I downloaded a MSWINSCK.OCX file. Then drag it into SysWOW64. Then gone to command prompt and run as administrator and typed in regsvr32 c:\windows\syswow64\MSWINSCK.OCX.
even tried with
downloading a MSWINSCK.OCX file. Then drag it into System32. Then gone to command prompt and run as administrator and typed in regsvr32 c:\windows\system32\MSWINSCK.OCX.
but displays the same message
The module
"c:\windows\system32\MSWINSCK.OCX" may not be compatible with the version of windows that you are running.Check if the module is compatible with an x86(32-bit) or x64(64-bit) version of regsvr32.exe
In the command prompt change directory to C:\Windows\SysWow64
then run
regsvr32 yadda yadda
there are 2 different regsvr32.exe on the system.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
thank you for your reply sir but still got the problem
Untitled.png i did as u instructed but it says the module yadda failed to load ........as seen in the image i have attached here.
when i type regsvr32 on cmd the says-" to register a module u must provide a binary name..".... Untitled.png
I have the same problem here
Dears
i have the same issue here and i have tried all ways to resolve it and till now didn't work
any help...!!
:cry::cry::cry:
    10 Pro
