Shut down problem + Sleeping problem
    Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K
    Problem 1:
    When i shot down my pc via windows Shot Down button pc doesn't go Off.
    I see Windows Off screen, screen goes black but pc still running.
    Problem 2:
    When my pc goes sleep or monitor goes sleep i can't wake up computer with mouse or keyboard.
    If i press any button i see changes on screen, like waking up but screen stays black...
    Attached energy report - via cmd command: powercfg -energy
    if this can help you
Is it my DVD writer problem or software driver problem?
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
Drivers & Hardware
Problem with checking for problem solutions Windows 8.1 PR
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
Performance & Maintenance
Context menu item problem and accessing files problem
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
Windows 8.1 problem with shut down and sleep
Hello, My windows 8.1 sometimes doesn't shut-down or go to sleep, but only blank screen and all the fans running and only way out is reset the system.It happens 3 out of 10 times. Please help me in troubleshooting. I have also attached SF diagnostic tool report for reference.
Windows 8 shut down problem
I have windows 8 x64 system. When I shut down my laptop, It waits in black screen from time to time, nothing happens if you don't use the power button to shut down. Sometimes it happens during the openning process. I had no such a problem before updating the windows. I have this problem for 2...
Sleeping Dogs problem
I can't download DirectX End-User Runtime I have Sleeping dogs but it won't start on Windows 8. After a bit of searching I came to know that if I install DirectX from this link Download DirectX End-User Runtime from Official Microsoft Download Center Sleeping Dogs...
Release Preview - Nothing but problem after problem after problem.
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
