Solved To Keep, or Not To Keep Metro?
realitykid
Banned
When you get your hand on the Consumer Preview of Windows 8, do you intend to keep Metro, or deactivate (given the option still exists)? As far as I know, you could do this in the Developer Preview with either a registry change, or a third part application. The end result would be a deactivated Metro UI, and a normal, Windows 7 style, Start menu in its place.
    Windows 8 Pro 64-bit, Windows 8.1 Pro Preview 64-bit
    Gateway NV59c
    Intel Core i3 2.27ghz
    4GB
    24" 1080p Sansui HDTV connected via HDMI
    1440x900
    320GB Seagate
    Dell Dimension 4500 Desktop:
    Pentium 4 Processor (2 GHz)
    1 GB DDR-RAM
    3x40GB Hard Drives (1 Seagate, 2 Western Digital)
    1x80 GB Hard Drive (Western Digital)
    Linux Mint Debian Edition
I will not disable Metro UI, unless that the "One Click ON/OFF Metro" option works for the CP
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
I would keep the Metro because it's very easy to switch between Metro and Desktop view, I like Metro UI.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
Well, I am glad someone finds it useful. I find it annoying and in the way. Especially since I don't have a touch PC or tablet. If I had a tablet, Metro would be perfect. Anyway, just seeing what others intend to do with it. :)
    Gateway NV59c
    4GB
    1440x900
    320GB Seagate
    1 GB DDR-RAM
Metro UI would be perfect if there were two start buttons, one for Metro and the regular one.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
Certainly not two sitting on the taskbar side by side. That'd just look clunky and ridiculous. However, having the option to disable Metro on the desktop should be something that Microsoft puts in the control panel.
If, at the release candidate, Metro isn't able to be disabled without some sort of tweak, I will be moving over to Linux permanently. Or unless I can get used to Metro and actually decide I really do like it. Time will tell.
    Gateway NV59c
    4GB
    1440x900
    320GB Seagate
    1 GB DDR-RAM
That's just your opinion, I can think of elegant ways to do that.
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
Well, yes, it is just my opinion. However, I stand by it.
Can you give me an example of a way that you'd do it so that way it actually looked good? The idea is great. Just, the aesthetics of it don't seem plausible if you're after something pleasing to the eye.
    Gateway NV59c
    4GB
    1440x900
    320GB Seagate
    1 GB DDR-RAM
That Metro will kill win 8, for the PC user.
    Win 7
    Dell Inspiron 570
    AMD x2
    Dell
    4GB
    ATI HD 5670
    2 x 500GB
    Corsair 600W
    Dell
    Logitech K300
    Logitech G400 Gaming
As I tend to keep my Machines in "sleep" mode when not in use, I don't see the Metro interface if I've gone into sleep via the Desktop (Win + I, or power management) therefore I'll keep it....whether I'll use it is a different matter...
Regards
Robin
    WIN7 Home Premium 64-bit
    Homebuilt
    Intel I7 920
    Asus P6T-Se
    6Gb
    Sapphire HD5770
    On-board
    ASUS VW246H, Samsing Syncmaster 2233, Samsung Syncmaster T200HD
    2 x 500Gb
    Coolermaster Silent Pro M700
    NOX
    Logitech Marble
    10Mbps
    Dell Inspiron 1501 with Win 8 CP 32 Bit - flying along!
Very possible. And most likely. However, too soon to tell at the moment. I just don't like feeling strong armed into something I don't want.
    Gateway NV59c
    4GB
    1440x900
    320GB Seagate
    1 GB DDR-RAM
Regards
Robin
lol. Ya, I usually just leave my laptop on. However, I usually don't use sleep. It's either shut down, or hibernate. And the hibernation-shutdown feature in Windows 8, I will be shutting that off. I don't want a possible slow down when I'm using it just because it never got a proper shutdown.
    Gateway NV59c
    4GB
    1440x900
    320GB Seagate
    1 GB DDR-RAM
I plan on keeping the Start Screen as it is. I finally found out how to get red tiles........YES! :cool: I hope the CP expands on Start Screen customization a lot more.
    ASUS
    AMD FX 8320
    Crosshair V Formula-Z
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
    Microsoft Touch Mouse
I'll kill it, if it hasn't been fixed
I'll see if they've fixed it.
If not, I'll kill Metro (if it can still be done).
    Windows 7 Ultimate SP1 (64 bit), Linux Mint 18.3 MATE (64 bit)
    n/a
    AMD Phenom II x6 1055T, 2.8 GHz
    ASRock 880GMH-LE/USB3
    8GB DDR3 1333 G-Skill Ares F3-1333C9D-8GAO (4GB x 2)
    ATI Radeon HD6450
    Realtek?
    Samsung S23B350
    Western Digital 1.5 TB (SATA), Western Digital 2 TB (SATA), Western Digital 3 TB (SATA)
    Tower
    Wired Optical
    Linux Mint 16 MATE (64 bit) replaced with Linux Mint 17 MATE (64 bit) - 2014-05-17
    Linux Mint 14 MATE (64 bit) replaced with Linux Mint 16 MATE (64 bit) - 2013-11-13
    Ubuntu 10.04 (64 bit) replaced with Linux Mint 14 MATE (64 bit) - 2013-01-14
    RAM & Graphics Card Upgraded - 2013-01-13
    Monitor Upgraded - 2012-04-20
    System Upgraded - 2011-05-21, 2010-07-14
    HDD Upgraded - 2010-08-11, 2011-08-24,
Well, I'm toying with Metro now. Not sure yet if I will keep it or not though. If I decide I don't like it, then it's back to Windows 7 for me and then the eventual switch back to Linux.
    Gateway NV59c
    4GB
    1440x900
    320GB Seagate
    1 GB DDR-RAM
I will leave Metro for a little while - just to see what it does. But if I were to use Win8 as a production system, I would get rid of it. For the desktop it is a genuine nuisance.
    Vista and Win7
    5 SSDs and 12 HDs
Metro is already gone.
    WCP
    HP
    2@ 4.9 Hz
    64 gig
    Nvidia 9600
    integrated
    laptop
    1440x900
    300gig internal and a bunch ext
    not much
    Built-in
    Logitch Anywhere Mx wireless mouse
    50 down 1.5 up
No it won't really. I love it I have a place to neatly organize a billion pieces of software for quick access that is easy to look at. You have to know how to set metro up for use on a pc with no touch input. If you were a graphic designer this is the absolute dream version of windows because you would be working from a highly sensitive touch input all the time as your primary display anyhow. I am picturing the Wacom Cintiq 24HD anyone else? I am also picturing a 3d secondary display just because. This OS has the potential to change the way we interact with a PC drastically almost overnight and will be the standard for years to come. Just watch and see. unless hologram monitors come out in a year and windows get another drastic overhaul that takes advantage of it...
Buy hey I almost forget to mention that if anything changes your resolution metro stays exactly the way you put it. The icons don't magically jump all over the damned place and need rearranged every time that happens. But hey you metro users can suffer on with a UI that is as old as I am I will be enjoying modern technology and saving time and effort while I work.
    Win7 Ultimate x64 SP1
    Custom Build (What Else Would It Be?)
    AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz
    Gigabyte GA-890FXA-UD5
    CORSAIR DOMINATOR GT 8GB (2 x 4GB) 1866 DDR3
    XFX HD-697A-CNDC Radeon HD6970 2GB 256-bit
    Creative SoundBlaster X-Fi Platinum Fatal1ty Edition
    Dual 25 Inch Hanns-G HZ251
    3840x1080 (1920x1080 x2)
    Corsair 850W Single Rail
    Thermaltake V9 BlacX w/ Dual HDD Docking Station
    Air/Copper
    Kensington (Low-Profile)
    Creative Fatal1ty
    Cable 15Gbit (15 Down 5 Up)
    XIGMATEK HDT-S1284F 120mm HYPRO Bearing CPU Cooler, LG Blu-Ray Burner.
