Need to reccord the system power on timings?
    How to find the Laptop power on timings for the whole day ,I want to record all the power on and power off timing details. Is there any software is there means please suggest me that, that to great Thanks.
    Sloe Deth, Californicatia
    It's all there in the System Event Logs. It clearly defines the state of the system in Boots, Sleep Mode and Hibernation.
    Here is how a Bootup looks:
    Here is how a shutdown looks:
    There are other states logged as well, it's all listed under KERNEL-BOOT, KERNEL POWER or KERNEL GENERAL
Unplugging power crashes system
Unplugging the power causes the system to crash. This is especially bad with a slippery power plug. I'd be immensely thankful for tips on getting the latest drivers. I haven't figured out why Intel's utility for detecting my system (Intel® Driver Update Utility) won't work for me. HP's...
BSOD Crashes and Debugging
Power Options - Add or Remove "System cooling policy"
How to Add or Remove "System cooling policy" in Power Options in Windows The System cooling policy power option allows you to specify the cooling mode you want to use for your system. Active = Increase fan speed to cool first, and only slow the processor to cool as a last resort. Passive...
Power Options - Add or Remove Link State Power Management
BSOD Driver State Power Failure + System Lag
Hi, my machine is breaking down here. I was recently helped but I guess that never worked.
System shuts off while power goes... with UPS On
Hi, My system shuts off automatically sometimes when the power goes with UPS on. UPS is not giving any beeps or warning signs though. At this time UPS seems On though. But my computer shuts off as if I unplugged its power cable. My UPS battery is new and UPS is 6 years old. Any help appreciated....
System doesn't power off completely, random crashes
Often, when turning off the pc, it doesnt power off completely (windows turns off, but the pc stays on, to poer off I need to press the power button for a few secons) and at the next startup, it displays a driver power state failure dump. Also, I seem to get some random system service exception...
Power icon missing in system tray.
Not sure if I should post it in Performance forum. I have a Acer Aspire 7741Z laptop. Guest OS ....... Win 8 RP in VMware player. Host OS ........ Win 7 Home Premium SP1. Issue.... Power icon is missing in the system tray. When I went to Customize > Turn System Icons On or Off > The...
