- Help - Extended monitor and laptop monitor not working
    Win 8
    Today I plugged an hdmi to vga cable into my Win 8 sony vaio, and I plugged the other VGA side of the cable into an acee 22" monitor. I then chose from the right hand windows 8 panel to "extend to monitor", the laptop screen went black, the monitor screen remained without signal (extended screen did not show on monitor) and now the laptop screen is black.
    I am now stuck and both laptop and monitor screen not working.
    I tried unplugging cable, pressing fn and all the f1 to f12, shift, windows button but nothing is working.
    I pressed off button then switched laptop back on and it showed the sony vaio logo on laptop then the screen went black again.
    Please tell me how could I return my laptop screen to work and stop the screen extension which is not working and which I am sure is the case.
    Any buttons on keyboard to click at all?
    Any solution is highly appreciated.
    Thank you
    Sloe Deth, Californicatia
    It's stuck in an extended screen it seems, boot into Safe Mode while you have all external monitors unplugged - Your Display is probably set to a resolution too high for both the external monitor and the laptop monitor, so you'll have to try "Boot to VGA mode" and I don't know where that is in the Windows 8 Boot GUI, if it is even in there at all.
    Here is is- There are several ways to get to that from the Boot screen:
    Advanced "Startup Settings" - Boot to in Windows 8
laptop with two VGA & external monitor
Hello I have a laptop with two VGA (intel & nvidia). I can connect external monitor with HDMI (clone mode), only with intel (from intel's menu). is there any way to connect the external monitor with the nvidia card?
Graphic Cards
HP Laptop--recovery through extended monitor
I have acquired an HP Envy M6 laptop (AMD version with ATI graphics) and I want to do a factory reset on it so I can customize it for me. Problem is the screen is broke so I have been using it with an external monitor until I can order the replacement screen. Problem I am running into is the...
How to change scaling resolution on extended monitor?
I currently have a 15" PC with a 3200x1800 resolution. Using Windows 8.1. I have the scaling to highest. My 2nd external monitor is 1920 x 1200. I am trying to extend my desktop to the 2nd monitor but is there a way to use different scaling for both the PC and monitor? I have unchecked...
Graphic Cards
2nd monitor not working
Hello this is the first time I've tried to set up a dual monitor for Windows 8. This is what happens: Note: If i set it as the tv for the main screen it works fine?
Graphic Cards
Dual Monitor - Secondary Monitor Flashing Issues
I recently purchased another monitor so I can run dual-monitors on my newly upgraded-to Windows 8 desktop. I set the monitor up last night, and I haven't had any major issues so far... One issue that I've run into, though, is the secondary monitor (regardless whether it's the monitor I owned first...
Graphic Cards
Reliability Monitor not working?
I downloaded and installed the new upgrade from Win 7 to Win 8 Pro on 25th Oct. Everything as gone well with the exception of the Reliability Monitor. It opens quickly enough but it only shows events from the period 16th to 20th Oct and states that it was last updated on the 20th Oct at 2300...
Performance & Maintenance
I downloaded and installed the upgrade from W7 to W8 on 25th Oct. All appears well except for the Reliability Monitor. It opens no problem but only provides details commencing on the 16th Oct to 20th Oct. It also states that it was last updated 20th Oct at 2300 hours. Is it possible to update it...
