Problem with battery Indicator
    Hello Everyone!
    I have windows 8 installed on my Acer Aspire TimelineX and everything is working great, but battery indicator keeps disappearing and showing up.I have already tried going to Device manager ----> action>scan for new hardware,but it disappears after I restart the computer.Any solutions?. THANKS IN ADVANCE
    Sloe Deth, Californicatia
    IS there an Fn key that shows you remaining battery? I have an Old Dell Inspiron 9100 laptop where the Battery icon would simply vanish.
    With Laptops, there is something like Dell Quickset which assigns some On Screen Graphics to the Fn Keys, so you can see what you are doing, like Volume Level, Remaining Battery, Brightness, etc.
    Acer should have a similar program- It usually replaces the "Mobility Center" - See if you can get the Mobility Center to show up as a taskbar tray icon. If your battery keeps on vanishing, maybe you can re-install the Acer version of Quickset, is there a folder on the main hard drive with the Drivers and Utilities stored? If not, you should be able to download the Utility from the Acer website that has the drivers and utilities for your laptop.
No Battery Indicator on my Acer
I have windows 8 installed on my Acer Aspire TimelineX and everything is working great, but sometimes I have the battery indicator, and sometimes I don't , I hate not knowing when my laptops gunna die, I included a screenshot to show you what I mean. 4083
Drivers & Hardware
battery indicator disappeared Windows 8.1
Hello, my friend got a new Asus Transformer T100 with Windows 8.1. The device was fine. We set up the Microsoft account and updated all the drivers, the firmware, Windows updates, as well as Windows Store app updates. But now the battery indicator is missing! It's not even on the pop-out when...
Remove the Volume Indicator?
Hello, I installed a different volume indicator for Windows 8, so the volume indicator that always appears is no longer needed. Does anyone know how to remove it? (Like, a registry edit or something) I'm talking about this one ^
Battery icon Problem, solve it.
Please help me, my battery icon is not showing the remaining battery life. And sometimes, my battery didn't detected even the battery is inserted correctly. But even though the charger is unplugged, I can use my laptop. I don't know what happen. So please help me. These are the screenshots of my...
Drivers & Hardware
Battery Indicator keeps showing 0% charging.
I just did a clean install of Windows 8 Pro on my 3 years old Asus Laptop. Everything seems to be working fine, except for the battery indicator and some Asus Fn keys.. The battery cannot be charged, it keeps showing 0% charging even after a few hours. I tried disabling and re-enabling the...
Drivers & Hardware
Battery Percentage Indicator - Is it available?
Hello, I've always enjoyed a battery percentage indicator on the taskbar. Where you can click or hover over & it will give the percentage left & approximate amount of time left on the battery. It appears that in Metro it will only show an image of a battery where you can kinda tell if it's...
Performance & Maintenance
Windows 8 Battery Indicator not seen
Windows 8 Battery Icon not seen but once you install Conexant Audio Codec it shows up
Drivers & Hardware
