I Mixed up the C and D drive after using System Suite recv
    win 8 pro
    I feel like an absolute moron but I somehow swapped the labels of c: and D: drive on my i5 Lenovo v570 running 8 gigs of ram and a replaced 750gb Seagate ssd hybrid.
    I was having a ton of issues with my installed win 7 and was unable to boot to the one key recovery program or anything else for that matter, So my system was clearly compromised.
    I spoke with Avast and the solution that they gave was that they could fix my registry, including factory reset for $119.00. I am currently on a pretty tight budget so I went out to try and track down a windows 7 disk. After 7 stores I gave up but came across this shiny box saying we will fix and super speed your computer and we even have a recovery disk included for Win 7. So I'm thinking great! An answer to my problem. So I save all of my graphic design work and anything else I wanted to keep on my arsenal of 12 flash drives that I usually have all dedicated to ready boost. And I launched the repair suite. Well I could see the Os on the D: drive so I left it alone but I was given delete as the only option for c: So I'm thinking this should work as good as the instructions state and the backup Windows 7 disk that was supposedly on the system suite version 12 CD by Avanquest, would allow for a clean install.
    Tells me to install my Windows disk which doesn't come with my computer nor available as a download from Lenovo.
    So I purchased Windows 8 Pro and popped in the 64 bit disk and it loads and boots up but the software is installed on the C drive partition, It even booted up and gave me the option of Win 7 or 8 but it wouldn't activate my Key so I spent about 5 hours with Microsoft Win 8 Support and they finally generated a new key which still didn't work. So I allowed the tech to log in remotely and he assures me that he'll get everything working great.
    Well I've got a million errors and I cant see most of the saved data on my USB flash drives.
    Is there an easy fix to get a clean copy of win 8 with the factory setting only bios and still access my files on my flash drives. I'm going out of my mind and would love a little guidance. I need to download my Adobe suite and get back to work asap.
    Any info would be greatly appreciated!
    Thanks - T
    ME, XP,Vista,Win7,Win8,Win8.1
    We always assume you have made your Recovery Disks using the OEM manufacturer's Recovery Media Creator app the first day you had your new PC.
    & made the Startup Repair CD.
    startup repair disc-create
    Did you make the OEM manufacturer's Recovery Disks?
    Lenovo Recovery
    Lenovo Support - Home (US)
    You can Order Lenovo Recovery Disks from here:
    Clean Install : Factory COA Activation Key - Windows 7 Support Forums
Can I move Documents folder on a mixed SSD/HDD system?
I have a laptop with an SSD and a "normal" rotating hard drive. The SSD is small (32Gb) so I want to reserve it for things that best belong on it, using the bigger (650Gb) HDD for the bulk of my storage needs. I assumed it would be easy to move the Users folder but no, it can't, so after much...
Users Mixed on Windows 8.1 RTM
Windows 8 News
A few mixed questions
Hi. I just got windows 8 and so far i like it :thumb:.... I do however dislike that there was no start menu..... Ive since downloaded classic shell which has fixed that problem..... I still have few little things i cant work out and would like some help pls.... (1) Why do I have to sign...
Mixed home networking environment
Can anyone explain to me the best configuration for a home network if I am using a mixture of different computers, including Win 7, 8, and a new-ish Mac? The Mac has Lion. I am just wondering if anyone knows if Macs are compatible with Homegroups or Workgroups or Domains? I am a little rusty on...
Network & Sharing
Accounts all mixed up
Just got a new computer with Windows 8 installed. I set up my user account with my comcast email, but then later decided I to use my gmail account (mostly because of the POP3 limitation in Win8). I find there is no way to change the e-mail address associated with that Windows account, so I...
User Accounts and Family Safety
Mixed bag of questions
Hey guys, I just installed Windows 8 yesterday, and so far I'm liking it! I have a few questions, (and I'm sure this list of questions will grow), so here goes. 1. Is there any difference between me using a local account to log in, or using my account? (Apart from, perhaps, my...
Mixed feelings about the cloud idea
Today, the clouds got heavy and grey, and when I turned on my computer and went to EightForums, and I thought it was going to rain personal documents and user profiles. :cry: So I took an umbrella, went out, and it was a file flood out there! I immediately tweeted this through my iPad which was in...
Chillout Room
