Monitor Problems, Random Lockups, General unhappiness!
    win 8 x64 pro
    G'day everyone,
    Just thought I'd see if anyone has had similar issues to me....and, more importantly, ways to fix them
    Basically, I have three main problems with Windows 8. They are:
    1. Monitors don't always work. I have 4 monitors, 2 DVI, 1 minDP and and USB. On reboots or if a monitor is turned off and on etc, one of the DVI monitors refuses to work. I've tried many things to correct it, and sometimes it does come back Once they are all on, they are fine.
    2. Lockups. Sometimes windows just freezes....not everything, just whatever I was using when it it is windows explorer, sometimes taskmanager etc.
    It seems every time I boot I get another little problem....last one was...a blank start key put me to desktop, windows key again....blank eventually came up....don't know why
    Some general info:
    OS was done as a full install onto an SSD.
    Video drivers are up to date from AMD. No other drivers have been updated, other than what windows found for them.
    Hardware is: Asus p8z77-v-pro mobo, 32G 1866 RAM, i5 3570k, AMD HD 6570.
    So, does anyone have any ideas? Thank you in advance!
    When you say "full install" do you mean you installed clean? You did not upgrade a previous version of Windows?
    win 8 x64 pro
    Sorry, yes I meant clean install.
    The monitor is the biggest annoying issue, crashes I can suss out eventually through trial and error...but I can't work out what to do to get the monitors all working.
    Windows 8 64 bit
    I've had freezes too. Windows Explorer several times. Have to go to Task Manager to close them.
    I have some of the same problems.
    If my monitor is off during boot, then 75% of the time it won't work when I turn on the monitor. The only choice is a hard reboot.
    I also get freezes, but for me it's the entire system that freezes.
    My system is similar: win8pro installed clean on SSD, the difference is that my cpu is i3550 and my video is nvidia gtx 660.
Monitor Sleep Problems
I have two monitors set up, and when they go to sleep, one turns back on when I move the mouse, and the other one doesn't. It is an ASUS V2228. I have played around with all kinds of setting with power management, and nothing seems to work. It is not a huge problem, all I have to do is turn...
Dual Monitor problems
Hi all, new to the forum. Running Windows 8.1, I just connected a second monitor. I can see both screens side by side and each do exactly the same thing. I tried to extend ( Windows Key + P ) but nothing happens. In fact nothing happens when you press any of the choices - second screen only, PC...
Graphic Cards
Random BSODs when not plugged into external monitor
I've been getting BSODs a few times a day when I'm not plugged into an external monitor. Sometimes I'll get an artifacted screen or just a random restart. I thought it might be an overheating issue so I took apart my computer and cleaned all the dust out. While it helped temperatures a little, it...
BSOD Crashes and Debugging
Monitor problems
Hello. I have my monitor set to turn off automatically after 30 minutes of inactivity in Power Settings, and my computer is connected to a monitor with HDMI. The monitor has built-in speakers, which are my primary speakers. When the monitor turns off after 30 minutes, I hear a "device...
Graphic Cards
Random Startup Lockups when Using Rapid Boot
My hardware specs are available here: Blue Phantom | MegaGames By default Windows has Faster starting on My UEFI also has a rapid boot function which I set to on (But not ultra rapid which requires a GPT formatted HDD/SSD) However on two occassions this has caused the system to lock...
Windows update caused general problems - programs crashing
After spending an inordinate amount of time getting my old applications to work with Win 8 (and giving up for some) I finally had a system that seemed to be working. Then File Explorer started to freeze. I saw that I had not installed the recent updates. So I did this. Now a whole bunch of programs...
