Problem with Sound Driver
    Okay well this is more or less trying to get my pink microphone jack...microphone working on my computer.
    While it should show up. it doesn't it does NOT come up under disabled it IS plugged in.
    I tried installing chipset drivers didn't help
    i TRIED installing sound drivers *which i know is what i need* "Setup is unable to detect a supported product on your system. Please ensure that your product is properly installed before running this Setup program.
    Setup will exit" i get this however.
    I am using a XPS 420 and upgraded to windows 8.1 awhile ago.
    I've been trying to find help on google and such and there was not much luck.
    Dell does not support Win 7/8/8.1 on this system. You will likely need to install a PCI Windows 8.1 compatible sound card or a USB connected Win 8.1 compatible sound card. The latest OS that Dell supports is Vista and the Vista drivers are incompatible with Windows 8.1.
    The Dell hardware is mostly proprietary in this model, thus I doubt you will find any useable Sigmatel sound drivers.
    I used to work the Dell forums and users upgrading older systems to new OS' had to install sound cards on many models as Dell drivers were not available.
sound driver
sir i have pentium (R) dual core E5400 ..i have windows 8 audio doesnot work Y? sound driver has been damaged so i patch up external audio what to do?..plz help me..
Drivers & Hardware
Stereo Mix? Also, Windows sound driver.
First of all, to all those having problems with sound, I would suggest the following. Go to Control Panel, Programs, and uninstall the audio driver. Reboot. Then try to play sound. You might think that you would not hear any, before installing a different audio driver, or reinstalling the...
sound driver installed still no sound
REALTEK AC97 sound driver installed Working fine!..showing status working but no sound:cry:..after updating PC to win 8..worked well for Win 7..Need Help..:zip:
ASUS Sound Driver?
Hi all, so my motherboard is an ASUS model M2N-E and I just managed to fix the problem that prevented me from successfully installing Windows 8 earlier today. Now that I'm running Windows 8, I plugged in a brand new set of Harman Kardon Soundsticks III and the sound quality is terrible. Very...
Drivers & Hardware
IDT sound driver
sir, i have HP PAVILION DV6 nd i m using windows 8 pro. i installed IDT audio driver (provided by HP for win 7) in win 8. it installed successfully bt its not working. it has no any effect it is just useless. can u give me any solution for this. suggest me IDT audio driver which is compatible with...
Sound Blaster X-Fi Driver
On Friday 10/26 I upgraded to Windows 8 Pro and found I still had the SB driver problem for the X-Fi which is not supported by Creative anymore since my system is now over 4 years old. I'm not sure exactly when this original X-Fi card came out. I tried different Creative drivers as I had in the...
Drivers & Hardware
cmedia sound driver not working
After installing Windows 8 Pro X64 was prompted to download cmedia sound driver to get m onboard sound chip to work.:( Downloaded the 64bt version, went to install and got message saying it wouldn't work with my system :shock:
