URGENT!! USB power surge HELP!!! USB not working anymore!
    I recently had a USB power surge on my Windows 8 tablet Acer Iconia W700
    And now my USB is no longer working. :/
    I have tried unstailling the USB drivers but when it's finishing Unstailling all the USB drivers my Windows 8 tablet always becomes unresponsive and i had to turn off the tablet after by switching the hardware/physical on/off button.
    I really really NEED the USB 3.0 working again as i can't transfer my video clips for Youtube or backup my stuff.
    So can anyone help me please? I was thinking of factory resetting my tablet again but i can't do it because of the USB not working!! :/
    This is the 1st time ever i had a USB power surge..
    Forever West
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    You had a power surge and the power/charging adapter is plugged into the USB port. It's a dual-purpose socket, also use for data transfer. When that port gets damaged it generally means getting a new one or sending yours in if still in warranty. Did you install/plug in a MicroSD/XD memory card? Could be your 'stuff' is on it and those small cards come with an adapter to plug into a standard USB port such on a computer for transferring data, might look for it, maybe behind a cover on one edge of the tablet like mine is, remove it and use the adapter. I have a Dell Venue 8 tablet with Win8.1 and my power/charging adapter also works with my cellphone and an Android tablet.
Region and Language not working anymore.
Hello i have bought a new computer with 8.1 . When i did the first setup and i had to choose the language i wanted italian but it wasn't there so i choose english and i downloaded the LP later. I installed all the updates inculded Update 1 and everything worked fine. After one week of normal use...
Bluetooth is not working Anymore
Greetings to all, I have been running win 8.1 for a while. At first Bluetooth was working fine. Then last week Bluetooth stopped working. Why, I have got a clue. What I did is just reinstall the drivers from ASUS web site but to no avail. I have looked at 'Event Viewer' but there is no error...
Drivers & Hardware
Windows 8 music player isn't working anymore
hello i used to use the new music player which came with windows 8 just yesterday it stopped working when i run it it doesn't work just the orange color and the headset appear what's wrong with it ?
Software and Apps
Thunderstorm readiness - surge woes - your approach?
The other day we were struck by some heavy bolts and the house literally shattered. Thor seemed pretty pissed at my neighborhood and I considered shutting down all the comps. Even if the house has surge protection and I also have (I do not know what it is called in English, surge protection...
Chillout Room
Live tiles not working anymore
Hello, I have the problem since a few weeks (mostly after a tile update), and I'm not the only one, my friend has it too on both his laptop and desktop, that the live tiles, or actually some of them, for example weather, are not refreshing anymore. It just shows the blue weather tile. When I...
Performance & Maintenance
Does windows 8 consumes more battery power? Urgent
hi my helping friends, i had windows 7 earlier , the rare of battery consumptions was 10 -14 watt hour as shown by battery meter gadget . then i installed windows 8 and installed windows 8 gadget pack then installed the battery meter gadget but the rate of consumption of battery was always 18 -22...
