Backlit Keyboad problem
    I have the dell inspiron 7520. I recently only noticed that the backlit keyboard does not fully dim even when I press the Fn+F6 button combination "twice". Is it normal?
    I'm talking about this
Black Border Problem / Reset Video Card Driver Problem
My PC was recently upgraded to Win-8.1. When it started up, my video card drivers were reset from ATI Radeon 4300/4500 Series, to Microsoft Basic Adapter. Along with that my PC now has an unsightly array of black borders around my screen. If anyone would help me with what is wrong it would be...
Problem with checking for problem solutions Windows 8.1 PR
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
Performance & Maintenance
Context menu item problem and accessing files problem
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
Problem deleting a file, REAL problem
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Backlit Keyboard Main Stream Laptop
Does anyone know of a PC manufacturer(s) that tends to offer Win8 laptop models with backlit keyboards at prices substantially less than the lessor MacBook Pro model with the DVD drive? I am looking for something with approximately the specifications below, but not the Apple price. I find many PC...
Drivers & Hardware
Removing the touch keyboad
I searched for this forever and finally decided to register and ask, I have a laptop with a touchscreen, it has a keyboard. I have no interest in using the on-screen touch keyboard. Any time a touch a textfield the touch keyboard appears and I have to manually close it, how do I prevent this...
Drivers & Hardware
Release Preview - Nothing but problem after problem after problem.
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
