I have a big problem NEED SOME HELP
    I factory resetted my Windows 8 tablet Acer Iconia W700 and it is working fine now, it's very fast..
    But today when i turned on my Tablet it goes to "choose your keyboard layout" then i pressed on United Kingdom.
    Then after you have 3 options the 1st one is "continue" to go to Windows 8
    The 2nd option is "troubleshoot" To factory reset or Refresh your PC
    And the last one is "turn off your PC"
    And i keep the pressing the 1st option to go to Windows 8 but it keeps restarting and going back to the "keyboard layout" page and i don't know why...
    I really don't want to factory reset my tablet again as i am editing a very long video for Youtube and i don't really want start all over again on editing my video.
    I really don't know what to do can someone help me please?
    Austin TX metro area
    Could you choose default keyboard and then once inside, change to your desired keyboard? Never used a Windows tablet, so I'm straw-grasping.
    Windows 3.1 > Windows 10
    choose troubleshoot refresh - it should (is suppose to away) keep existing files..
Is it my DVD writer problem or software driver problem?
Here is my problem When i write my DVD-R with Nero/Imgburn/Burnaware it says burnt successful but it fails to verify and even dvd is blank when i reinsert in laptop and my friends computer. I have tried to burnt at slower speeds but still same problem.:rolleyes: My dvd drive reads other DVDs...
Drivers & Hardware
Problem with checking for problem solutions Windows 8.1 PR
When I try to check for a solution to a problem (Control Panel\System and Security\Action Center\Problem Reports) a warning appears telling me to connect to the Internet or to try later… 44832 The problem is that I am connected to the Internet while I receive this message and now I do not see...
Performance & Maintenance
Context menu item problem and accessing files problem
I have 2 issues. I don't know if they are related somehow. 1. I installed PrivaZer and deleted it. It still shows up on the right click context menu. I tried to reinstall it and deleted it again. I still have that problem. I even restarted the computer. How can I get rid of the entry? 2....
Problem deleting a file, REAL problem
So i'm trying to delete this file i have in my downloads folder, which is a normal .avi file. however, this file is really broken, it wont delete. I suspect this file makes my folder not showing thumbnails and acting slow and sometimes wont show anything at all, just a loading bar thing. i...
Shut down problem + Sleeping problem
Hey, running Windows 8.1 64bit, Asrock Z87E-ITX mobo, Intel 4770K Problem 1: When i shot down my pc via windows Shot Down button pc doesn't go Off. I see Windows Off screen, screen goes black but pc still running. Solution? Problem 2: When my pc goes sleep or monitor goes sleep i can't...
Release Preview - Nothing but problem after problem after problem.
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
