Solved Installing a 3 pin -> 2 pin connector for PWR LED
Hbomb
Ug. I'm trying to set up a new motherboard in my rig, and I note that the motherboard has only 2 pins for this, wheras the case has a 3 pin connector. There's no room for the extra pin, and the 3 pin adapter is encased in hard plastic as shown. Does anyone have experience with this? What would you do?
attachment.php
there are little tabs - locking the pins in place (they look white in your pic) lift those tabs with a needle or small pic and pull the pins out of the connector
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
Some motherboards have an extra 3 pin connector next to the normal front panel connector for the 3 pin type power led.
What mother board do you have?
    Windows 8.1 Pro x64 with Media Center, Windows 10 Pro x64, Windows 7 x64 Ultimate SP1
    Custom System
    INTEL Xeon E5-2670 LGA 2011
    Gigabyte GA X79 UD5 v1.0 F13s
    64GB (8 X 8 GB) G-Skill Ripjaws Z DDR3 2133 Quad Channel
    EVGA GTX 1060 SC 3 GB
    Realtek Onboard ALC898
    2 x Samsung S27E310
    Samsung 850 PRO 256 GB SSD
    1 x 6TB WD 6003FZBX SATA
    13 x 3TB WD 30EFRX SATA
    Seasonic X-1050
    Thermaltake Armor+
    INTEL BXRTS2011LC Liquid-cooled
    Logitech G510s
    Microsoft Wireless Explorer Mouse
    7.0 Mb/s
    IE 11, Chrome
    ESET NOD32 11.1, Malwarebytes Pro 3.5.1
    ASUS RT-AC68U router
many times over the years I have cut the black plastic removing one wire ,but I don't suggest that to you ,what I suggest is a new cheap case .maybe at newegg or tigerdirect
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
Please provide your case and motherboard brands and model numbers so we can verify the correct process.
    W10 Pro
Be careful lifting the locking tabs, they will break off quit easily. Been there done that.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Thanks man. I ended up doing this and wrapping the exposed metal in electrical tape. Make sense?
Case is an Antec Solo
Motherboard is Gigabyte 990 FXA UD3
those are the same type connectors that are used in Radio Control Electronics.. so been there and done that many times.. You are just looking to slightly lift the tab not pry it up..
    Dell XPS 8700
    I7
    24 GB
Oh? Not according to your manual on page 25 where it clearly shows the 3-pin connector from that case goes across 3 pins of the Front Panel Header (pins 15, 17, and )19.
Note there may only be 2 wires but the connector is a 3-pin.
Make sure you are not confusing the power switch with the power LED.
    W10 Pro
:thumb: You know that and I know that, I wasn't sure the OP knew it though.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
I have never seen a locking tab on Front Panel wiring connections on the motherboard
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
I think I know what your referring to, like on the power supply connector that plugs into the mother board. We're talking about a little tab that holds the metal contact in the plastic shell. If you lift it slightly you can pull the wire and the contact and all comes out. You'll be left with the wire and the metal contact that's crimped to its end in one hand, and the plastic shell in the other.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
But this is about the case's front panel wires that connect to the motherboard's Front Panel I/O, not power supply cables that connect to the motherboard's power connectors. So I agree with caperjack and there should NOT be any locking tabs. If you reverse the connectors from the case's front panel, no harm will be done. The power and reset buttons will still work and at most, the LED lights for power and HD activity will not light.
If there are locking tabs, then someone has the cables mixed up.
    W10 Pro
the image in the first post is not something that comes a part ,[with out a pair of wire cutters ],not in any machine I have ever worked on ,or built since 1998
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
I think before we jump to any conclusions we need to wait until the OP comes back and responds to my post #9 above.
    W10 Pro
Ah, you can actually see the retaining tab in those pictures. If you look at one on one of the case cables, one side has a small opening where you can see the metal connector inside. If you carefully lift the little bit of plastic below the opening, towards the wire, the wire and metal contact will slide out. Push it back in the same way it came out and it will latch back into the plastic cover again. All those case cables with the black plastic covers are like that. When I was still working as an electronic technician, we had the pins, covers and crimping tool to make our own cables for equipment we fabricated.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
They're talking about removing the wire from the housing itself. The wire terminals have a metal tab and the housing itself has a plastic tab. When the terminal is inserted into the housing the 2 tabs lock the terminal in place so it stays in place. KYHI described lifting the plastic tab to release the terminal but in my experience it's easier to use a pick tool or even a paper clip to push down on the metal tab of the terminal itself which will release the terminal and let you remove it without cutting the wire.
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet)
    Home built i7-8700K, Hp Envy x360 EVO Laptop, MS Surface Pro 7
    3.7Ghz Core i7-8700K, 11th Gen Core i7-1165G7 4.7Ghz, 10th Gen Core™ i5-1035G4 1.1Ghz
    ASUS TUF Z370-Pro Gaming, HP, MS
    16G, 8G, 8G
    AMD Radeon RX580, Intel Iris X Graphics, Intel Iris Plus Graphics G4
    ATI High Definition Audio (Built-in to mobo)
    Dual Samsung U32J59 32 inch monitors, 13.3" display, 12.3" display
    3840x2160 (Desktop), 1920x1080 (laptop), 2736x1824 Pro 7
    500GB ssd boot drive with 2 & 10TB Data (Desktop), 512GB ssd (laptop), 128GB SSD (tablet)
    Corsair CX 750M
    Antec 100
    Coolermaster CM 212+
    IBM Model M - used continuously since 1986
    Microsoft IntelliMouse
    665Mbps/15Mbps down/up
    FireFox, MS Edge
    Defender on all
    Retired in 2015 after working in the tech industry for 41 years. First 10 years as a Technician, the rest as a programmer/software engineer. After 1 year of retirement, I was bored so went back to work as a Robotic Process Automation Consultant. Retired for 3rd (and final) time in 2019.
Yes I know, I was just using the power cable as an example of a connector that has a locking tab on it to keep in mated with the plug it plugs into.. Locking tab as in you can't unplug the connector without releasing the locking tab. That's what I thought Caperjack was referring to.
The tab in question is one to release a wire and the metal end crimped to it from the shell. Two different tabs.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
maybe so ,I must have missed that feature ,will have to did out a old computer and have a look ,
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
